View and edit dwg file without opening AutoCAD
I want to be able to load a dwg file and that it is visualized either from the browser or through a desktop application and allows me to modify the existing elements either eliminating or adding new features
BKSpurgeon
This link will tell you how to open an existing drawing:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-NET/files/GUI...
As far as the other particulars of your question: I didn't understand.
Virupaksha_aithal
Autodesk Support
Autodesk Support
see if AutoCAD web provides you the required functionality. Refer http://through-the-interface.typepad.com/through_the_interface/2018/03/the-future-of-autocad.html
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
