Vertical Dimension Text Placement
mgorecki
Message 1 of 1
mgorecki
Ok, we all know that when you add a vertical dimension (and the text does not fit between the extension lines) the text gets placed either up and to the right, or down and to the left.
What if you wanted the dimension to be up and to the left or bottom and to the right?  Has anyone found a way to force the dimension text and leader to be placed like that programatically?  I know you can change the dimension manually, but I want to do it with the program.
Thanks in advance.
Mark
Replies (0)
