Vector3d.ProjectTo not working as expected
I want to project an mtext direction vector onto the z plane. The thing is I don't want an orthogonal projection, I need to project it in the same direction of the mtext's direction vector. I don't know how to explain it right.
This is what I tried to do:
Vector3d proy = mtext.Direction.ProjectTo(Vector3d.ZAxis, mtext.Direction);
This returns (0,0,0), which obviously isn't the result I'm expecting.
_gile
Whatever the projection plane, if you project a vector using this vector direction, you'll always get a null vector (this is what the code you show does).
You should explain what you're trying to achieve and or provide some drawing
Gilles Chanteau
GileCAD
GitHub
My aim is to transform ANY mtext so it's looking upwards (it's normal vector equals (0, 0, 1)).
I don't want the mtext's rotation, etc.. to be altered, so I'm doing this using the TransformBy() method.
I want to achieve this in two steps:
1 - Rotate the mtext's normal's perpendicular vector
Vector3d mtextRotatedNormal = mtext.Normal.TransformBy(Matrix3d.Rotation(Math.PI / 2, mtext.Direction, mtext.Location));
Until the direction vector's Z value equals 0 (I need to calculate the correct angle for this transformation).
2- Rotate the mtext's direction vector until the mtextRotatedNormal vector's Z value equals 0.
With these two steps the mtext's normal should equal (0, 0, 1) but I cannot obtain the right angles for the rotations.
I was trying to obtain that vector for the calculation of the first angle.
_gile
This should work:
var location = mtext.Location;
var plane = new Plane(Point3d.Origin, mtext.Normal);
mtext.TransformBy(Matrix3d.WorldToPlane(plane));
mtext.Location = location;
Gilles Chanteau
GileCAD
GitHub
I tried something similar. It almost works but it's direction vector is not correct.
When I execute the code you provided, the mtext's direction is changed.
_gile
Like this?
var pt = mtext.Location;
double rot = Vector3d.XAxis.GetAngleTo(mtext.Direction, Vector3d.ZAxis);
mtext.Location = pt;
mtext.Rotation = rot;
Gilles Chanteau
GileCAD
GitHub
