VB.NET Mtext style
VB.NET Mtext style
Sgear
Message 1 of 8
VB.NET Mtext style
Sgear
Hi
How can I set style to mtext
Regards
Sgear
           Dim objIniFile As New clsIni("c:\file\text.ini")
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim db As Database = doc.Database
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            ed.Regen()
            Using tr
                Dim pt As Point3d = ed.GetPoint(vbLf & "Select: ").Value
                Dim mtx As New MText()
                mtx.Location = pt
                mtx.SetDatabaseDefaults()
                mtx.TextHeight = 1
                mtx.Width = 35
                Dim HK = objIniFile.GetString("MAIN", "HK", "")
                Dim TP1 = objIniFile.GetString("MAIN", "TP1", "")
                Dim TP2 = objIniFile.GetString("MAIN", "TP2", "")
                Dim TP3 = " " + objIniFile.GetString("MAIN", "TP3", "")
                Dim TP4 = objIniFile.GetString("MAIN", "TP4", "")
                mtx.Contents = ("{\C1;" + HK + "}\P" + ("{\C1;" + TP1 + "}\P" + ("{\C1;" + TP2 + "}" + ("{\C3;" + TP3 + "}\P" + ("{\C3;" + TP4 + "}\P")))))
                mtx.SetAttachmentMovingLocation(mtx.Attachment)
                Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                btr.AppendEntity(mtx)
                tr.AddNewlyCreatedDBObject(mtx, True)
                tr.Commit()
            End Using
Replies (7)
Message 2 of 8
_gile
Did you try setting MText.TextStyleId property ?
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
SENL1362
              string textStyleName = "MtextStyle";
                using (Transaction tr=db.TransactionManager.StartTransaction())
                    var tsId = db.Textstyle;
                    var ts = (TextStyleTable)tr.GetObject(db.TextStyleTableId, OpenMode.ForRead);
                    if (ts.Has(textStyleName))
                        tsId = ts[textStyleName];
                    var mtext = new MText();
                    mtext.SetDatabaseDefaults();
                    mtext.TextStyleId = tsId;
                    tr.Commit();
Message 4 of 8
SENL1362
sorry Gile.
Message 5 of 8
Sgear
_gile, SENL1362 Thanks for the help I can know use Mtext style
Regards
sgear
Message 6 of 8
jan_tappenbeck
Hi!
i think this will be my code (what a english Smiley Happy ).
                    tr.Commit();
my problem is to us in vb.net.
my try looks like
                        If TextStyleName.Length > 0 Then
                            Dim ts As TextStyleTable
                            Dim tsID As Autodesk.AutoCAD.DatabaseServices.TextStyleTableRecord
                            ts = CType(acTrans.GetObject(acCurDb.TextStyleTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite), TextStyleTable)
                            If ts.Has(TextStyleName) = True Then
.. but then my knowledge is end.
could someone help me?
regards Jan
Message 7 of 8
_gile
    ' initialize tsId with current text style ID
    Dim tsId As ObjectId = acCurDb.Textstyle
    Dim ts As TextStyleTable = CType(acTrans.GetObject(acCurDb.TextStyleTableId, OpenMode.ForRead), TextStyleTable)
    ' if the text style table contains a text style named as TextStyleName, set tsId with this text style ID
    If ts.Has(TextStyleName) Then
        tsId = ts(TextStyleName)
    Dim mtext As MText = new MText();
'... End If
As it looks like you just start learning .NET, I'd suggest you to learn C# instead of VB, because, as you can see you'll need, at least, to be able to read C# examples, even if you learn VB...
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
jan_tappenbeck
Dear Gilles,
since 1,5 years i work by vb.net to AutoCAD - but Primary in topobase map.
in last 2 month i need more or less direct AutoCAD entities!
you understand?
reagards Jan
