VB.NET Import Image
Hi
I am insert Image I export from Arcmap into Autocad Map with this sample
need to set the Width and Height and Scale and right please in the map
if I use .NET the image are not on same X Y if I use .NET or Autocad to Import the Image
this is X Y I get with Export from arcmap in the .TFW file
Dim X = "353917.0678034420"
Dim Y = "398701.9004743111"
if I import Image with Autocad then this is the X Y
X = '353917.018
Y = '398423.450
http://adndevblog.typepad.com/autocad/2012/05/how-to-insert-a-rasterimage-using-the-net-api.html
<CommandMethod("INSERTIMAGE")> _ Public Sub CmdInsertImage() ' Image dictionary name constant Dim dictName As String = "IMAGE" Dim imageDef As RasterImageDef Dim imageDefId As ObjectId Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor Using trans As Transaction = db.TransactionManager.StartTransaction Try Dim imageDictId As ObjectId = RasterImageDef.GetImageDictionary(db) If imageDictId.IsNull Then ' Image dictionary doesn't exist, create new imageDictId = RasterImageDef.CreateImageDictionary(db) End If ' Open the image dictionary Dim imageDict As DBDictionary = trans.GetObject( _ imageDictId, OpenMode.ForRead) ' See if our raster def in the image dict exists, ' if not, create new If imageDict.Contains(dictName) Then ' Get the raster image def imageDefId = imageDict.GetAt(dictName) imageDef = trans.GetObject(imageDefId, OpenMode.ForWrite) Else ' Create a raster image definition ' Get the file name of the image Dim fileDia As New Autodesk.AutoCAD.Windows.OpenFileDialog( "Open an Image file", Nothing, "jpg; gif; tif; bmp", "Image File", Autodesk.AutoCAD.Windows. OpenFileDialog.OpenFileDialogFlags.NoUrls) ' Show the dialog and test the result Dim res As System.Windows.Forms.DialogResult = fileDia.ShowDialog() If res <> System.Windows.Forms.DialogResult.OK Then Return ' Create a new image definition imageDef = New RasterImageDef() ' And set its source image imageDef.SourceFileName = fileDia.Filename() ' finally load it imageDef.Load() imageDict.UpgradeOpen() imageDefId = imageDict.SetAt(dictName, imageDef) trans.AddNewlyCreatedDBObject(imageDef, True) End If ' Now create the raster image that references the definition Dim image As New RasterImage() image.ImageDefId = imageDefId Dim X = "353917.0678034420" Dim Y = "398701.9004743111" Dim uCorner As New Vector3d(366, 0, 0) Dim vOnPlane As New Vector3d(0, 278, 0) Dim point As New Point3d(X, Y, 0.0) Dim coordinateSystem As New CoordinateSystem3d(point, uCorner, vOnPlane) image.Orientation = coordinateSystem ' And some other properties image.ImageWidth.ToString(366) image.ImageHeight.ToString(278) image.ImageTransparency = True image.ShowImage = True ' Add the image to ModelSpace Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead) Dim msBtr As BlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite) msBtr.AppendEntity(image) trans.AddNewlyCreatedDBObject(image, True) RasterImage.EnableReactors(True) image.AssociateRasterDef(imageDef) trans.Commit() Catch End Try End Using End Sub
