VB.Net getting eLockViolation error with OpenMode.ForWrite
Jedimaster
Jedimaster
I have a VB.NET routine that is supposed to batch process drawing files finding and replacing text. I am having the user create select drawing files the routine writes the file names and locations to a text file. Once the drawing list written, it is opened and the drawings are processed one by one. The processing is handled by a subroutine that collect all text and mtext entities. Then the routine searches and replaces all matches, save and close. If I manually open and run the findandreplace subroutine it works fine. If it runs though the BatchRoutine I'm getting eLockViolation error on the OpenMode.ForWrite portion of the routine. I can resume on error and it does not crash out but does not make changes. In some of the other posts I was reading about AcAxDocLock but only found examples of C++.
Any help or insight would be much appreciated.
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.ApplicationServices.DocumentCollectionExtension
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Windows
Imports System.IO
Public Class Main
<Autodesk.AutoCAD.Runtime.CommandMethod("Test")>
Public Sub BatchRoutine()
If File.Exists(FileList) Then
If File.ReadAllLines(FileList).Length = 0 Then
MsgBox("No drawing files found!" & vbCrLf & "Aborting!")
Exit Sub
Else
Dim sr = New StreamReader(FileList)
Dim CurrentDrawingFile As String
Do While sr.Peek() >= 0
CurrentDrawingFile = sr.ReadLine()
If File.Exists(CurrentDrawingFile) Then
Dim dm As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Dim doc As Document = dm.Open(CurrentDrawingFile, False)
Dim ActiveDrawing As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
If ActiveDrawing.IsReadOnly = False And ActiveDrawing.IsActive = True Then
Call FindandReplace()
Else
MsgBox(ActiveDrawing.Name & " is Read Only")
ActiveDrawing.SendStringToExecute("QSAVE" & vbCr & "QSAVE" & vbCr, True, False, False)
DocumentExtension.CloseAndDiscard(ActiveDrawing)
Loop
sr.Close()
Else
MsgBox("File list was not found!" & vbCrLf & "Aborting!")
Exit Sub
End Sub
Public Sub FindandReplace()
Dim CurrentFind As String = "TEXT TO FIND"
Dim CurrentReplace As String = "TEXT TO REPLACE"
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim acTypValAr(3) As TypedValue
acTypValAr.SetValue(New TypedValue(DxfCode.Operator, "<or"), 0)
acTypValAr.SetValue(New TypedValue(DxfCode.Start, "TEXT"), 1)
acTypValAr.SetValue(New TypedValue(DxfCode.Start, "MTEXT"), 2)
acTypValAr.SetValue(New TypedValue(DxfCode.Operator, "or>"), 3)
Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
Dim acSSPrompt As PromptSelectionResult
acSSPrompt = ed.SelectAll(acSelFtr)
If acSSPrompt.Status = PromptStatus.OK Then
Dim acSSet As SelectionSet = acSSPrompt.Value
Dim trans As Transaction = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction
For Each selObj In acSSet
Select Case selObj.ObjectId.ObjectClass.Name
Case "AcDbText"
Dim WtextObj As DBText = trans.GetObject(selObj.ObjectId, OpenMode.ForWrite, False, True)
Dim RtextObj As DBText = trans.GetObject(selObj.ObjectId, OpenMode.ForRead, False, True)
Dim OldTextString As String = RtextObj.TextString
Dim NewTextString As String = Replace(OldTextString, CurrentFind, CurrentReplace, 1, -1, CompareMethod.Text)
RtextObj.Dispose()
If OldTextString <> NewTextString Then
WtextObj.TextString = NewTextString
WtextObj.Dispose()
Case "AcDbMText"
Dim WmtextObj As MText = trans.GetObject(selObj.ObjectId, OpenMode.ForWrite, False, True)
Dim RmtextObj As MText = trans.GetObject(selObj.ObjectId, OpenMode.ForRead, False, True)
Dim OldTextString As String = RmtextObj.Contents
RmtextObj.Dispose()
WmtextObj.Contents = NewTextString
WmtextObj.Dispose()
End Select
Next selObj
trans.Commit()
End Sub
End Class
_gile
I cannot attentively read your code (unformated VB is too much for me) but if you want to be able to open multiple documents in the editor you have to use the CommandFlags.Session argument in the CommandMethod attribute and lock each document you want to edit.
See here and there.
<Autodesk.AutoCAD.Runtime.CommandMethod("Test", CommandFlags.Session)>
    Using(doc.LockDocument())
        ' edit the document here
    End Using
End Sub
Gilles Chanteau
GileCAD
GitHub
What  @_gile said will fix the problem you are facing ( eLockViola tion) but I'd make two more changes in your code:
1) Make sure MdiActiveDocument is set:
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = doc
2) Add an using statement to your transaction to make sure it's properly disposed.
Not ending a transaction leads to weird errors in AutoCad Interface (see this😞
      Using tr As Transaction = db.TransactionManager.StartTransaction
        tr.Commit()
      End Using
