VB_NET Create a block with solid
Hi there,
    I'm new in .net and I find some example so I'm konw hot to make a Block with lines and circles and how to make a solid extruded by a region maked with a closed polyline.
But I'm trying to make a block with inside a solid (same described before) and I can't find the solution or examples on the web,
can someone help me?
C# code wiil be good as well
Thank you
_gile
AutoCAD entities always own to a BlockTableRecord (which may be the model space, a paper space or a bloc definition).
So you add the Solid3d (or any other entity) to the BlockTableRecord of your block definition with the Appendentity method as you do to add an entity in the model space.
Gilles Chanteau
GileCAD
GitHub
