Utility Classes - A Start
Message 1 of 26
I was thinking about a form I am currently designing for a dialog that will allow the user to label coordinates in Model Space. I was thinking in particular about some controls that could probably take advantage of common code wrapped into a GUIHelper class.
I wanted to ask if someone might share the following code with me, if it is available.
[1] I need to fill a ListBox with all of the layers that exist in a drawing. I was thinking we could create a method that accepts a ListBox as an argument and then fills it with the existing Layers. If someone can share with me their code for accessing a list of existing layers in a drawing I will write the rest of the method and stick it in the GUIHelper class.
[2] I'm not sure how convoluted the logic is to display the Layer Dialog Box. If involves more that one or two method calls I thought we could wrap this in another method of the GUIHelper class. This will allow the button to show the dialog with a single call like helper.showLayerDialog(). Can anyone share with me the code needed to open the LayerDialog?
[3] I'll need to come up with a dialog that allows the configuration of MText entities that are created by some of my tools. (For example, the text containing the coordinate values of a selected point for my current tool.) I was wondering if we could come up with a standard dialog box and supporting classes that can be used for this purpose. If I design the code for this will someone review it and comment?
P.S. - I have set up a spot in my SVN repository at the SurveyOS SourceForge Project for my AutoCAD .NET code. I will release it under the GPL. As soon as I have some time I will post a link to the Project website, the repository, and instructions on how to contribute. I welcome other developers that would like to collaborate and share code to contact me about placing a module on the SVN.
Scott Huey Message was edited by: Sunburned Surveyor
Replies (25)
Message 21 of 26
Thanks for all the comments of support.
I really should have thought more carefully about my entrance to this forum, and my approach in try to set up an open source library for AutoCAD .NET code. I didn't realize that there is still some skepticism about the open source development model. It would have been better to start the library with a release of some of my own code.
I can't change the past. Instead I will be working to mend fences and build consensus as I move forward. I may have been a little short with Tony and some of the others in this thread, and for that I apologize. I look forward to learning and sharing from everyone on this forum in the coming months.
Scott Huey
Message 22 of 26
Scott,
No need to be apologetic. There's absolutely nothing wrong with ruffling the
feathers of the so called professionals.
Davis
Message 23 of 26
> Oh, and Owen, I don't think it should be an accepted initiation rite
> of any newsgroup that, as a newbie trying to learn, I should have
> to put up with Tony's sarcasm and condescending comments.
That would be nice, but no utopian vision is going to change the reality
on the ground. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Message 24 of 26
I will watch with interest and if I see anything that requires my skill level (knuckle dragger) I will likely jump in. In the past I have tried to start a collaborative effort on a VB project in another forum. It was surprising how little interest there was. Maybe times and attitudes have changed. I personally don't get the Open Source thing. It almost seems like a religion to those that promote it.
With regard to Tony.
I can't think of anyone I've learned more from here than Tony. He has never been rude with me but then I don't post much and I haven't poked him with a stick.
I have noticed that people that offer unsound programming advice seem to set him off.
I feel that this helps to set the bar a little higher for all of us. The best teacher, the one that pushes you to excel, is not necessarily the nicest one.
Message 25 of 26
Well said!
Message 26 of 26
Yup. I had some college professors like that.
If open source is a religion I guess you would call me a religious fanatic. :]
Scott
