Using Xrecord and Binary Serialization
I am using this function to retreive xrecord data save along with the drawing
public TypedValue[] loadByteStream(string dictionary)
TypedValue[] bts=null;
try
using(Transaction trans=db.TransactionManager.StartTransaction())
DBDictionary NOD = (DBDictionary)trans.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
DBDictionary dictLegs = (DBDictionary)trans.GetObject(NOD.GetAt(dictionary), OpenMode.ForRead);
Xrecord XRec = (Xrecord)trans.GetObject(dictLegs.GetAt(dictionary), OpenMode.ForRead);
trans.Commit();
bts=XRec.Data.AsArray() ;
catch(Autodesk.AutoCAD.Runtime.Exception exp)
ed.WriteMessage(exp.Message);
return bts;
the problem is when i work with drawing using the .net debug mode it work smoothly
however when i open acad separately and use netload to load the application
it gives Fatal Error
i am definite that line bts=XRec.Data.AsArray() ; is causing the exception.
Any Solution.
PS: this happens for some drawings not all
It wouldn't suprise me that you get this, but I think
its most likely linked to what's in the xrecord. If you
can't get it into an array, that's not just a significant
issue, its a show stopper that should never have made
it into a production release.
So, can you post an example DWG file with an xrecord
that throws the exception?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:[email protected]...
try
trans.Commit();
return bts;
Any Solution.
As Requested please find attached the dwg file causing the mentioned errors
The dictionary name is ISODRAWING
let me know if more clarification is required to finalize this issue Message was edited by: ckassouf
