using SelectionFilter to select feature lines (Elementkante)
reithinger
reithinger
IHi,
I have this selectionFilter in my Code
// Filter für Linien jeglicher Art
         AcDataService.TypedValue[] tvPolyline =
                new AcDataService.TypedValue(-4, "<or"),
                new AcDataService.TypedValue(0, "ARC"),
                new AcDataService.TypedValue(0, "CIRCLE"),
                new AcDataService.TypedValue(0, "ELLIPSE"),
                new AcDataService.TypedValue(0, "LINE"),
                new AcDataService.TypedValue(0, "MLINE"),
                new AcDataService.TypedValue(0, "*POLYLINE"),
                new AcDataService.TypedValue(0, "RAY"),
                new AcDataService.TypedValue(0, "SPLINE"),
                new AcDataService.TypedValue(0, "XLINE"),
                new AcDataService.TypedValue(0, "TRACE"),
                new AcDataService.TypedValue(0, "SOLID"),
                new AcDataService.TypedValue(0, "FACE"),
                new AcDataService.TypedValue(0, "AECC_ALIGNMENT"),
                new AcDataService.TypedValue(0, "AECC_FEATURELINE"),
                new AcDataService.TypedValue(-4,"or>")
I need to add the featureLine, but it doesn't.
Have you got any Idea or it's impossible ?
Thanks for your response
Jeff_M
Use "AECC_FEATURE_LINE"
Jeff_M, also a frequent Swamper
reithinger
Tanks !!
It works.
How can i find the right property ?
Alfred.NESWADBA
if you don't know the internal name of an object (dxf-name) you can use this LISP statement:
(ssget (car (entsel)))
The result in the command-line then shows the properties of this object, for code 0 you'll see the name that can be used for selection filtering.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
_gile
The LISP expression should be:
(entget (car (entsel)))
Or, to directly get the DxfName:
(cdr (assoc 0 (entget (car (entsel)))))
Gilles Chanteau
GileCAD
GitHub
Alfred.NESWADBA
@_gile  ... thank you, don't know what I was thinking about while writing something like that 😉
- alfred -
Alfred NESWADBA
Jeff_M
Or, just use the ACAD LIST command:
Command: LI LIST
Select objects: 1 found
Select objects:
AECC_FEATURE_LINE Layer: "C-TOPO-FEAT"
Space: Model space
