Using REVCLOUD with Editor.Command()
tvhlong93
Message 1 of 11
tvhlong93
I need to use the REVCLOUD command via .NET. But when I use the command by Editor.Command(), it has different options between using the REVCLOUD command in AutoCAD.
Why are the options different? And how can I get all the options? Please help me with this problem. Thank you.
Command: MYCOMMAND
Minimum arc length: 0.5000 Maximum arc length: 0.5000 Style: Normal Type: Freehand
Specify start point or [Arc length/Object/Style] <Object>: *Cancel*
Select insertion point: *Cancel*
Command: REVCLOUD
Minimum arc length: 12.0000 Maximum arc length: 12.0000 Style: Normal Type: Rectangular
Specify first corner point or [Arc length/Object/Rectangular/Polygonal/Freehand/Style/Modify] <Object>: *Cancel*
Replies (10)
Message 2 of 11
Virupaksha_aithal
Autodesk Support
Autodesk Support
can you please share the code which can be used to reproduce the issue..like
[CommandMethod("testREVCLOUD")]
public void testREVCLOUD()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
ed.Command("_.REVCLOUD", "_Arc", 4.0, 4.0);
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Message 3 of 11
tvhlong93
Sorry for the late response. Here's the code.
[CommandMethod("MYCOMMAND")]
public static void TestRevCloud()
    Document doc = acApp.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    double scale = 12;
    ed.Command("_.REVCLOUD", "_ARC", 0.25 * scale, 0.25 * scale);
This is message when I use the "MYCOMMAND"
Command: MYCOMMAND
The following message is when I use the "REVCLOUD" which is the AutoCAD command
Command: REVCLOUD
Minimum arc length: 0.5000 Maximum arc length: 0.5000 Style: Normal Type: Rectangular
They show different options when picking a point and the command sent through Editor.Command doesn't have options like "Rectangular", "Polygonal",.. and it forces the user to use the "Freehand" type only.
Message 4 of 11
Virupaksha_aithal
Autodesk Support
Autodesk Support
not sure why you are getting the mentioned results in AutoCAD. I am attaching the output of your code at my end.autocad_commandline.png
Message 5 of 11
tvhlong93
Yes, the command only has three options: [Arc length/Object/Style]. Options in the image are missing (in red color).
I want my custom command to act like a normal REVCLOUD command which has full option.
For more information, I am referring to AutoCAD 2020 API.
Message 6 of 11
Virupaksha_aithal
Autodesk Support
Autodesk Support
Thanks for the image. Try SendStringToExecute API. This API normally simulates AutoCAD UI behavior.
Note : SendStringToExecute works asynchronously .
Message 7 of 11
Alexander.Rivilis
You can try set Editor.InitCommandVersion
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 8 of 11
tvhlong93
I still have some code after that so I skip this method at the start. The answer of Alexander.Rivilis has solved this problem with Editor.InitCommandVersion(2).
Thank you for your support.
Message 9 of 11
tvhlong93
Thank you very much.
Do you have any information about the input version, please send me the document about it for reference if you have one. I can only find the information below but it doesn't help much. Anyway, I tried with Editor.InitCommandVersion(2) and it worked as expected.
Message 10 of 11
Alexander.Rivilis
@tvhlong93
Sorry, but there is no other (public) document, which describe using this method.
Also read this post: https://adndevblog.typepad.com/autocad/2015/10/creating-a-rectangular-revcloud-using-acedcommands.ht...
Expert Elite Member
Message 11 of 11
tvhlong93
Thank you. I get the ideas.
