Hello, I have a problem . Hope somebody could correct me. I am going to collect objectid's of the moved items in drawing after they moved to destination. So I wrote an event to monitor move command , by using object modified event handler. when I run below code for every entity it collects 2 object id. One before move and one after move. Is there any way to just collect object ids after they moved?
Thanks for any help.
Janet.
Class EVENTS
Dim MyDwg As Document = Application.DocumentManager.MdiActiveDocument
Dim Myed As Editor = MyDwg.Editor
Dim Mydb As Database = MyDwg.Database
Dim Myobjidcoll As ObjectIdCollection
Sub On_Command_Will_Start(ByVal sender As Object, ByVal e As CommandEventArgs)
Select Case e.GlobalCommandName
Case "MOVE"
Dim Myobjidcoll As New ObjectIdCollection
AddHandler Mydb.ObjectModified, AddressOf Myobj_Moved
End Select
End Sub
Sub Myobj_moved(ByVal sender As Object, ByVal e As ObjectEventArgs)
Myobjidcoll.Add(e.DBObject.ObjectId)
End Sub
End Class
