Using GeometricExtents with UCS problems
I've looked around at some other posts but can't find the answer to my problem.
I am trying to get the distance from the insertion point of a block and the maxX, maxY of an attribute of the block. My routine works fine when there is no UCS, however, the MaxPoints I get back when there is a UCS present is different. This is the line of code I'm using.
                                       AttEndPt = NewPoint2d(attref.GeometricExtents.MaxPoint.X, attref.GeometricExtents.MaxPoint.Y)
The point returned is different if there is no UCS and when there is a UCS.
Any suggestions would be greatly appreciated.
thanks
cj
Hallex
Perhaps like this
AttEndPt = New Point3d(attref.GeometricExtents.MaxPoint.TransformBy(blkRef,BlockTransform).X, _
attref.GeometricExtents.MaxPointTransformBy(blkRef,BlockTransform).Y)
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Thanks Hallex,
It turns out it was more of a problem in my logic..got it working the way I needed to.
cj
The saga continues..... Although I have altered my logic, still have an issue.
What I really need to do is find the coordinate that represents the end of an Attribute value when there is a UCS present.
Have tried using the GeometricExtents, with and without the transformby and can't seem to get where I need to be.
Not sure of what logic to use, try and get the length of the text of the Attribute value, then apply that to the insertion point, but I can't seem to do this with UCS coordinates.
Can anyone provide some insight or any suggestions on the easiet way to do this?
thanks
cj
