using backgroundworker get xref file names
working on backgoundworker using autocad library dll. need to get xreffiles from a file where I need to use database services. I am not able to get databaseservices please suggest what dlls required to be added to get xref names from file.
Haritha
ActivistInvestor
Haritha
You cannot use the AutoCAD .NET API from a BackgroundWorker (or from any thread started by your code), because a great deal of the API is not thread-safe.
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
                    as BlockTable;
                    foreach (ObjectId btrId in bt)
                        BlockTableRecord btr = tr.GetObject(btrId, OpenMode.ForRead)
                        as BlockTableRecord;
                        if (btr.IsFromExternalReference)
                            btr.UpgradeOpen();
                            String oldPath = btr.PathName;
how to get this xref path name by using backgroundworker. how to get blocktable.
Please reply if anyone already done.
Y.Haritha
