Urgent Need Help
Urgent Need Help
Urgent Need Help
Hi All,
I want to select all the dimensions and assign unique names or parameters to them in Autocad Drawing..
For Rotated dimensions(D1=--,D2=--,D3=--..........)
Angular dimensions(A1--,A2--.........)
Radial Dimensions(R1=--,R2=--........)
This goes on for all kind of Dimensions
Here is the code what i have designed but the problem is that
i assigns same name to all the dimensions
Dim sset As AcadSelectionSet
Dim acdim As AcadDimension
Dim angle As AcadDimAngular
Dim radius As AcadDimRadial
Dim rot As AcadDimRotated
Public FilterType(1) As Short
Public FilterData(1) As Object
Private Sub Button7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button7.Click
sset = acadDoc.SelectionSets.Add("s2")
sset = acadDoc.SelectionSets.Add("Name")
FilterType(0) = 0
FilterData(0) = "DIMENSION"
FilterType(1) = 67
FilterData(1) = "0"
sset.Select(AcSelect.acSelectionSetAll, , , FilterType, FilterData)
j = 1
For Each acdim In sset
acdim.TextOverride = "d" & j & "=<>"
' 'radius.TextOverride = "rad" & "=<>"
' 'angle.TextOverride = "ang" & "<>"
j = j + 1
acdim.Update()
Next acdim
Here's you're code (rewritten) in .NET for dimensions
AutoCAD 2008, VS2005
already build, load the DimensionTextOverride.dll in the bin folder with netload.
(not checked if it works in Autocad 2007)
A Caddie
You will need to check the type of each dimension and use appropriate prefix:
[code]
If TypeOf acdim Is AcadDimAngular Then
acdim.TextOverride = "ang" & j & "="
ElseIf TypeOf acdim Is AcadDimRadial Then
acdim.TextOverride = "rad" & j & "="
Else
acdim.TextOverride = "d" & j & "="
j += 1
acdim.Update()
Next acdim
[/code]
HTH,
Alan
Thank You ,
it worked.my next problem is adding prefix to the text which is already overridden.
