UpdateCurrentPaper
UpdateCurrentPaper
FRFR1426
UpdateCurrentPaper
FRFR1426
I change the paper format on a layout with:
PlotSettingsValidator.SetPlotConfigurationName(layout, deviceName, media)
 But the paper doesn't update when I reduce the size (A0 to A1 for example). I've found that I have to call:
plSetVal.SetZoomToPaperOnUpdate(layout, true);
UpdateCurrentPaper(LayoutManager.Current.UnmanagedObject, true);
In order to force the update. AcApLayoutManager::updateCurrentPaper is not exposed in the .NET API, so I had to P/Invoke it. On AutoCAD 2013, I've found it in accore.dll, but I'm not able to found it on AutoCAD 2010. Someone knows where I can found it? Or a workaround? The doc says that the update may be triggered after the call to SetZoomToPaperOnUpdate by a notification, but how to force the sending of this kind of notification without updateCurrentPaper?
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
hyperpics
Have you tried to call:
Editor.Regen()
FRFR1426
Yes, and UpdateScreen too. Only UpdateCurrentPaper seems to work.
Maxence DELANNOY
Manager
http://wiip.fr
Alexander.Rivilis
@FRFR1426 wrote:
...AcApLayoutManager::updateCurrentPaper is not exposed in the .NET API, so I had to P/Invoke it. On AutoCAD 2013, I've found it in accore.dll, but I'm not able to found it on AutoCAD 2010. Someone knows where I can found it? Or a workaround?...
It is look like you have to write wrapper (with ObjectARX C++) for this method.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
hyperpics
I have used the following code to update the paper size and other properties of a plot settings object for a layout without any problems.  Maybe it will help you.  If not, then the only other option is to P/Invoke the method you mention.  I do remember having some strange issues with getting the paper size to display correctly when I was working on my AU handouts, but did manage to work around it though and did not need to P/Invoke any extra functions.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.PlottingServices
' Creates a new page setup or edits the page set if it exists
<CommandMethod("CreateOrEditPageSetup")> _
Public Shared Sub CreateOrEditPageSetup()
    ' Get the current document and database, and start a transaction
    Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
    Dim acCurDb As Database = acDoc.Database
    Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
        Dim plSets As DBDictionary = _
            acTrans.GetObject(acCurDb.PlotSettingsDictionaryId, OpenMode.ForRead)
        Dim vStyles As DBDictionary = _
            acTrans.GetObject(acCurDb.VisualStyleDictionaryId, OpenMode.ForRead)
        Dim acPlSet As PlotSettings
        Dim createNew As Boolean = False
        ' Reference the Layout Manager
        Dim acLayoutMgr As LayoutManager = LayoutManager.Current
        ' Get the current layout and output its name in the Command Line window
        Dim acLayout As Layout = _
            acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), _
                              OpenMode.ForRead)
        ' Check to see if the page setup exists
        If plSets.Contains("MyPageSetup") = False Then
            createNew = True
            ' Create a new PlotSettings object:
            '    True - model space, False - named layout
            acPlSet = New PlotSettings(acLayout.ModelType)
            acPlSet.CopyFrom(acLayout)
            acPlSet.PlotSettingsName = "MyPageSetup"
            acPlSet.AddToPlotSettingsDictionary(acCurDb)
            acTrans.AddNewlyCreatedDBObject(acPlSet, True)
        Else
            acPlSet = plSets.GetAt("MyPageSetup").GetObject(OpenMode.ForWrite)
        ' Update the PlotSettings object
        Try
            Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
            ' Set the Plotter and page size
            acPlSetVdr.SetPlotConfigurationName(acPlSet, _
                                                "DWF6 ePlot.pc3", _
                                                "ANSI_B_(17.00_x_11.00_Inches)")
            ' Set to plot to the current display
            If acLayout.ModelType = False Then
                acPlSetVdr.SetPlotType(acPlSet, _
                                       DatabaseServices.PlotType.Layout)
            Else
                                       DatabaseServices.PlotType.Extents)
                acPlSetVdr.SetPlotCentered(acPlSet, True)
            ' Use SetPlotWindowArea with PlotType.Window
            'acPlSetVdr.SetPlotWindowArea(plSet, _
            '                             New Extents2d(New Point2d(0.0, 0.0), _
            '                             New Point2d(9.0, 12.0)))
            ' Use SetPlotViewName with PlotType.View
            'acPlSetVdr.SetPlotViewName(plSet, "MyView")
            ' Set the plot offset
            acPlSetVdr.SetPlotOrigin(acPlSet, _
                                     New Point2d(0, 0))
            ' Set the plot scale
            acPlSetVdr.SetUseStandardScale(acPlSet, True)
            acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit)
            acPlSetVdr.SetPlotPaperUnits(acPlSet, PlotPaperUnit.Inches)
            acPlSet.ScaleLineweights = True
            ' Specify if plot styles should be displayed on the layout
            acPlSet.ShowPlotStyles = True
            ' Rebuild plotter, plot style, and canonical media lists
            ' (must be called before setting the plot style)
            acPlSetVdr.RefreshLists(acPlSet)
            ' Specify the shaded viewport options
            acPlSet.ShadePlot = PlotSettingsShadePlotType.AsDisplayed
            acPlSet.ShadePlotResLevel = ShadePlotResLevel.Normal
            ' Specify the plot options
            acPlSet.PrintLineweights = True
            acPlSet.PlotTransparency = False
            acPlSet.PlotPlotStyles = True
            acPlSet.DrawViewportsFirst = True
            ' Use only on named layouts - Hide paperspace objects option
            ' plSet.PlotHidden = True
            ' Specify the plot orientation
            acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees000)
            ' Set the plot style
            If acCurDb.PlotStyleMode = True Then
                acPlSetVdr.SetCurrentStyleSheet(acPlSet, "acad.ctb")
            Else
                acPlSetVdr.SetCurrentStyleSheet(acPlSet, "acad.stb")
            ' Zoom to show the whole paper
            acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, True)
        Catch es As Autodesk.AutoCAD.Runtime.Exception
            MsgBox(es.Message)
        End Try
        ' Save the changes made
        acTrans.Commit()
        If createNew = True Then
            acPlSet.Dispose()
    End Using
End Sub
