Update BlockTableRecord without Transaction
CJModis
CJModis
It possible to open BlockTableRecord for selected BlockReference, then DELETE all entities and ADD new entities without any of Transaction?
kerry_w_brown
Have you tried it ?
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-NET/files/GUI...
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
CJModis
Yes. i try it. I can delete entities from BlockTableRecord, but i can not add new entities
_gile
This works for me:
        [CommandMethod("TEST")]
        public void Test()
            var db = Application.DocumentManager.MdiActiveDocument.Database;
            using (var btr = (BlockTableRecord)SymbolUtilityServices.GetBlockModelSpaceId(db).Open(OpenMode.ForWrite))
                foreach (ObjectId id in btr)
                    if ((id.ObjectClass.Name == "AcDbLine"))
                        using (var line = (Line)id.Open(OpenMode.ForWrite))
                            double radius = line.Length / 2.0;
                            var center = line.GetPointAtDist(radius);
                            line.Erase();
                            using (var circle = new Circle(center, Vector3d.ZAxis, radius))
                                btr.AppendEntity(circle);
Anyway, I do not know why you can not or do not want to use a transaction, but instead of a regular transaction, you can use an OpenCloseTransaction which is mainly a wrapper for the Open / Close process used in the upper code.
        [CommandMethod("TEST2")]
        public void Test2()
            using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                var btr = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
                        var line = (Line)tr.GetObject(id, OpenMode.ForWrite);
                        line.Erase();
                        var circle = new Circle(center, Vector3d.ZAxis, radius);
                        tr.AddNewlyCreatedDBObject(circle, true);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
ActivistInvestor
You can delete entities from a BlockTableRecord without having to open it. It's the entities that you are deleting that you must open for write.
To add entities to a BlockTableRecord, you have to open it for write. If the BlockTableRecord is a record for an anonymous block, there's little point to deleting its contents. You should just create another new anonymous BlockTableRecord and populate it, then change the BlockTableRecord property of the BlockReference to reference the new BlockTableRecord. When the old one is no longer referenced by an BlockReferences, it will be discarded automatically.
About avoiding the use of Transactions, please see this previous post.
CJModis
Activist_Investor написано:
Are there any examples for this? exactly for anonymous blocks
CJModis
CJModis написано:
Don't need)) I translated it and understand what did you mean
