Update a parametric dimension value using .NET (C# or VB)
Can somebody point the way to the API for interfacing with parametric features already in a drawing? Basically take values fed into .NET to change the existing parametric dimensions so the geometry will auto update. Is this just a standard drill down into a table to find the needed dimension label and starting a transaction to change the value or does the new API have specific methods for doing this?
moogalm
Autodesk Support
Autodesk Support
You need to use AssocVariable.SetExpression API to update params in drawing ,yes what you mentioned is the standard procedure to access\modify a param. I believe you are aware of these blogs which speaks about AssocNetwork framework API.
-A simplified .NET API for accessing AutoCAD parameters and constraints
http://through-the-interface.typepad.com/through_the_interface/2011/08/a-simplified-net-api-for-acce...
-Working With Associtative Params
http://adndevblog.typepad.com/autocad/2012/03/working-with-associative-parameters-from-api.html
Philippe's blog was spot on. Thank you!
Is there any COM/ActiveX  object or other COM API which does the same thing which is done  by AssocVariable.SetExpression in .NET form?
