Txt File Symbol problem C# or Excel
k005
Advisor Advisor
k005
Hello.,
I am creating a .txt file from AutoCAD with this code.
There is no problem when I open the .txt file with Notepad. But when I import it into Excel, the symbol ø = looks like this = ø
Where can this come from?
Thanks.
        private void button1_Click(object sender, EventArgs e)
            string sPath = Environment.GetFolderPath(Environment.SpecialFolder.Desktop)+ @"\Donatilar.txt";
            string s1="";
            foreach (object item in listBox1.Items) s1 += item.ToString() + "\n";
            Clipboard.SetText(s1);
            //Encoding.GetEncoding("iso-8859-9")
            System.IO.StreamWriter SaveFile = new System.IO.StreamWriter(sPath);
            foreach (var item in listBox1.Items)
                SaveFile.WriteLine(item);
            SaveFile.Close();
           MessageBox.Show(sPath + "  oluşturuldu !");
essam-salah
 @k005
so when you copy/paste from *.txt to excel the symbol changes, would you give a sample *.txt file , because  i just copy/paste-ed from.txt to excel and it works fine
k005
@essam-salah
I'm adding the file.
There is no problem when I copy / Paste.
But I am importing in .txt file to Excel. The problem is in this case ..
Now let me try on Another Computer ... Will the same problem continue ...
Thanks.
essam-salah
hi @k005
man idk what is your problem, i just imported the file you attached to excel and it works fine,
watch the attached video.
k005
@essam-salah
Yes, that's okay. But I use an Excel macro. there is the problem ...
The file is attached.
k005
@essam-salah
I found the solution.
Thank you.
 System.IO.StreamWriter SaveFile = new System.IO.StreamWriter(sPath, false, Encoding.Default);
