Trouble with Debugging using visual studio
vkpunique
vkpunique
I am using autocad 2015 with visual studio 2023 community addition to build small autocad addin. But since last fews days i've trouble starting plugin in debug mode. Building project without debugging is working fine. Currenlty i have to manually load dll file to test. Starting debuging in autocad just casing "FatalExecutionEngineError" error.
Anyone having similar issue? I am only having this issue since last 2 days, i am using windows 11.
kerry_w_brown
Perhaps Try :
Build a new 'HelloWorld" minimal project and try to debug that.
Make a decision how to continue after that test.
ps: VS 2023 ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
kerry_w_brown
quick search returns this
https://forums.autodesk.com/t5/revit-api-forum/debugging-in-vs-does-not-work/m-p/10597302/highlight/...
you may be lucky 🙂
vkpunique
I found same solution over stackOverflow but visual studio 2022 don't have option for Use Managed Compatibility Mode in debugging
vkpunique
Found solution.
I've created new plugin for autocad with package manager. this is set to automatically load on every autocad start. after removing all installed plugins from Autocad, everything is working fine.
