Trouble with AttachmentPoint.TopCenter
GTVic
Advisor Advisor
GTVic
When I create DBText with a TopCenter alignment, the text comes out "Aligned" with a Height of 0 and Angle of 0. Any other value for the attachment point seems to work fine.
tsTable = CType(Trans.GetObject(AcadDoc.Database.TextStyleTableId, OpenMode.ForWrite), TextStyleTable)
Align = AttachmentPoint.TopCenter
TextEnt = New DBText
TextEnt.SetDatabaseDefaults()
TextEnt.TextString = TextString
TextEnt.Position = New Point3d(InsPoint)
TextEnt.Justify = Align
If Align <> AttachmentPoint.BaseLeft Then TextEnt.AlignmentPoint = New Point3d(InsPoint)
TextEnt.Height = Height
TextEnt.ColorIndex = Color
TextEnt.Rotation = Angle
TextEnt.TextStyle = tsTable(Style)
TextEnt.Layer = Layer
btr = Trans.GetObject(AcadDoc.Database.CurrentSpaceId, OpenMode.ForWrite)
btr.AppendEntity(TextEnt)
Trans.AddNewlyCreatedDBObject(TextEnt, True)
Trans.Commit()
I've seen that, too. You can set the attribute's VerticalMode and HorizontalMode separately to achieve a TopCenter justification.
-drg
GTVic
Thanks, I'll give that a try.
GTVic
That worked, here is the code I used:
{code}
If Align = AttachmentPoint.BaseLeft Then
ElseIf Align = AttachmentPoint.TopCenter Then
TextEnt.VerticalMode = TextVerticalMode.TextTop
TextEnt.HorizontalMode = TextHorizontalMode.TextCenter
Else
{code}
