Trim 3D Polyline
Trim 3D Polyline
jhdempsey
Trim 3D Polyline
jhdempsey
Hi All
Whats the best method to trim a 3D Polyline?
Ive already worked out the points where i want the trimmed polyline to start and end, but im struggling to find out a way to perform the actual trim.
I tried setting the StartPoint and EndPoint properties to the points i wanted, but that gives a NotImplementedException error, and all other examples on this forum seem to relate to 2D or LW polylines which didnt work for 3D polylines or the methods/properties used dont exist on a 3D polyline
Anyone able to help?
_gile
I would use the GetSplitCurves() method.
Gilles Chanteau
GileCAD
GitHub
heyimsp12
Hi @_gile
Since GetSplitCurves() method is available for Polyline2d as well, I'm assuming the same can be done for 2d Polylines. However, I always run into eInvalidInput error and I don't understand why. Could you help?
//Here is my piece of code.
Plane xyPlane = new Plane(Point3d.Origin, Vector3d.ZAxis);
var proj_EyePath = (Polyline2d)EyePathCurve.GetProjectedCurve(xyPlane, Vector3d.ZAxis);
//Trim EyePath
//Here StartPoint and EndPoint are two 3d Points.
Point3dCollection splitPoints = new Point3dCollection();
splitPoints.Add(proj_EyePath.GetClosestPointTo(StartPoint, false));
splitPoints.Add(proj_EyePath.GetClosestPointTo(EndPoint, false));
DBObjectCollection splitCurves = proj_EyePath.GetSplitCurves(splitPoints); //Error: Invalid Input
norman.yuan
You may want to try to reverse the order of adding split points to the splitPoints collection.
If there is multiple split points, the points added to the Point3dCollection should be sorted ascendingly by the distance to the start point of the curve being split.
Norman Yuan
Drive CAD With Code
