Transform point coordinates
BestFriendCZ
Message 1 of 20
BestFriendCZ
Hi
Could somebody help me with the transformation of points? I have point of nested block which have totally different coordinates like in UI. I have some confusion about it. i tested some type of transformation but without success. Thanks for any help 🙂
my code
 [CommandMethod("Test", CommandFlags.Session)]
        public void Test()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                db.ResolveXrefs(true, false);
                BlockTableRecord mspace =(BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                string blkName = "CP DIGGING HOLE_3";
                if (bt.Has(blkName))
                    BlockTableRecord btr =(BlockTableRecord)tr.GetObject(bt[blkName], OpenMode.ForRead);
                    foreach (ObjectId id in btr.GetBlockReferenceIds(true, false))
                        BlockReference br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                tr.Commit();
Pic 1Pic 1
Pic2Pic2
Replies (19)
Message 2 of 20
BestFriendCZ
Little progress BlockTableRecord does not contains my blocks without explode parent block. Doesn't matter of using COM API or .NET. API. Hmmm this is bad ... It look like there is no possible get coordinates of nested  block without explode parent block... Or am i wrong? 😊
Message 3 of 20
_gile
If the block references you're looking for positions are first level nested, you can use tne blockTransform matrix of the parent block reference.
        [CommandMethod("Test")]
        public static void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            using (var tr = db.TransactionManager.StartTransaction())
                var mspace = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                string blkName = "bloc"; //string blkName = "CP DIGGING HOLE_3";
                    var btr = (BlockTableRecord)tr.GetObject(bt[blkName], OpenMode.ForRead);
                        var br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                        var owner = (BlockTableRecord)tr.GetObject(br.OwnerId, OpenMode.ForRead);
                        // if the owner is a layout (i.e., the block reference is not nested)
                        if (owner.IsLayout)
                            ed.WriteMessage("\nPosition: {0}", br.Position);
                        // else, the owner is a block definition (i.e., the block reference is nested)
                        else
                            foreach (ObjectId parentId in owner.GetBlockReferenceIds(true, false))
                                var parent = (BlockReference)tr.GetObject(parentId, OpenMode.ForRead);
                                ed.WriteMessage("\nPosition: {0}", br.Position.TransformBy(parent.BlockTransform));
                tr.Commit();
If the refernces may be deeper nested, you have to do this recursively.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 20
BestFriendCZ
Hi Gile,
thanks for information. I will try make it recursively because my block is on 3.level . BTW: I still learn AutoCAD API and in past i used many your code examples on this forum. Really good job ... newcomers will appreciate it 😊
Message 5 of 20
BestFriendCZ
it's working:) thank for teach me something new
Message 6 of 20
kerry_w_brown
josef,
because you are new to the API and keeping in mind people looking for this solution in the future, it would be a good idea for you to post your solution.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 7 of 20
BestFriendCZ
Hi Kdub,
i just only modified sample code for my purpose. Here is current test code
[CommandMethod("GetBlockPosition", CommandFlags.Session)]
        public void GetBlockPosition()
            try
                            if (owner.IsLayout)
                            else
                                    ed.WriteMessage("\nPosition: {0}", TransformCordinates(parent, tr, br.Position.TransformBy(parent.BlockTransform)));
                    tr.Commit();
            catch (Exception e)
                ed.WriteMessage($" Critical error: { e.Message} ");
                return;
        private Point3d TransformRecursively(BlockReference btr, Transaction tr, Point3d nestedPoint)
            try
                var owner = (BlockTableRecord)tr.GetObject(btr.OwnerId, OpenMode.ForRead);
                BlockReference parent =null;
                    nestedPoint = nestedPoint.TransformBy(parent.BlockTransform);
                    break;
                if (parent != null)
                    TransformRecursively(parent, tr, nestedPoint);
                return nestedPoint;
            catch
                return new Point3d();
Message 8 of 20
BestFriendCZ
Do you think it will be possible ... write something similar without COM API? only using AcadBlockReference and etc..
Message 9 of 20
kerry_w_brown
I can't see any references to COM code in your posted example.
I can't imagine why you would want to use COM code.
Message 10 of 20
BestFriendCZ
meaby i wrong described it.....but this code i can't use in exe application ... and this is my main problem atm...  i need modify one function in large project which is wrote using another API...code work with object like acadblockreference  and not with blockrerefence... if i will use any objects from Acdbmgd or another dll like this so exe app fire error immediately....what i wrote on forum there is no way use this dll in exe app...My plan is change this project to this API but it will takes some time ... so i try to find faster solution
Message 11 of 20
BestFriendCZ
i mean what i read 🙂 sry for my englisch ... if there is way how to use it i would like to know:)
Message 12 of 20
norman.yuan
I am not sure the other post about nested block's coordinate was also from you (using different user name alias?). After all the discussion, and you say you are doing EXE. So, yes, you are correct that AutoCAD .NET API dlls cannot be used with EXE app (at least not directly). While I am not fan of using EXE to control AutoCAD (via AutoCAD COM API), which can hardly be a good business solution in most cases, it is rather simple to do what you want (getting real location/coordinates of a nested block presenting inside a block reference) with COM API. Here is sample code in AutoCAD VBA that just does that (assume only one level of nesting for simplicity):
Option Explicit
Public Sub TestNestedBlock()
    Dim ent As AcadEntity
    Dim blk As AcadBlockReference
    Dim pt As Variant
    On Error Resume Next
    ThisDrawing.Utility.GetEntity ent, pt, vbCr & "Select a block:"
    If ent Is Nothing Then Exit Sub
    If TypeOf ent Is AcadBlockReference Then
        Set blk = ent
        FindNestedBlockLocations blk
    Else
        MsgBox "Selected entity is not a block!"
End Sub
Private Sub FindNestedBlockLocations(bref As AcadBlockReference)
    Dim nestedBlk As AcadBlockReference
    Dim count As Integer
    Set blk = ThisDrawing.Blocks(bref.Name)
    For Each ent In blk
            Set nestedBlk = ent
            GetNestedBlockLocation nestedBlk.InsertionPoint, bref.InsertionPoint
            count = count + 1
    Next
    If count = 0 Then
        MsgBox "Selected block does not have a nested block inside!"
    Else
        MsgBox count & " nested block(s) found!"
End Sub
Private Sub GetNestedBlockLocation(basePt As Variant, brefPt As Variant)
    Dim location(0 To 2) As Double
    location(0) = brefPt(0) + basePt(0)
    location(1) = brefPt(1) + basePt(1)
    location(2) = brefPt(2) + basePt(2)
    MsgBox "Found nested block at: " & vbCr & _
        "X=" & location(0) & vbCr & _
        "Y=" & location(1) & vbCr & _
        "Z=" & location(2)
End Sub
Well, if you go the COM API route, then it would be better to post here.
HTH
Norman Yuan
Drive CAD With Code
Message 13 of 20
BestFriendCZ
Hi Norman,
no i write on forum only under my nick. SporadicCoder have totally different level englisch opposite me. To this problem i created only this post:
Alternative COM API vs .NET API
Problem about coordinates
and reason was becuase i found everytime additional problem. I am not fan using EXE too and i agree with your opinion on it but if you have to modify large project (thousand and thousand line of code) which was created by someone else like exe App so it is problem.
My plan is rewrite complete project like DLL but it takes some time and i am still learn AutoCAD... Thank you for your sample i will test it and i apologize for the inaccurate description of my problem.
Message 14 of 20
BestFriendCZ
I tested sample code and it return the wrong coordinates ...i tryed to make recursively and after only explode parent block and select child block which contains nested block and result was wrong too.. sample code works only on first nested block in base block
I decided to rewrite this part of code to DLL and return result somehow... but now i have problem with rotation all coordinates are good
Parent block have good rotation ... first nested block have good rotation too but second nested block have rotation 0 and good is 1.5.... (90°). I would like to know what is wrong at this code?
 [CommandMethod("ScanBlocks")]
        public void ScanBlocks()
            using (DocumentLock acLckDoc = doc.LockDocument())//lock mother window during print
                    RXClass blockReferenceType = RXClass.GetClass(typeof(BlockReference));
                    DBDictionary layouts = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                    foreach (var lay in layouts)
                        if (lay.Key.ToLower() == "model")
                            Layout layout = (Layout)tr.GetObject(lay.Value, OpenMode.ForRead);
                            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(layout.BlockTableRecordId, OpenMode.ForRead);
                            foreach (ObjectId id in btr)
                                if (id.ObjectClass == blockReferenceType)
                                    //get all blocks which are type BlockReference on first level in model layout
                                    BlockReference baseBlock = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                                    //loop through all blocks reference
                                    LoopNestedBlocks(tr, baseBlock,null);
       private static void LoopNestedBlocks(Transaction trParent, BlockReference brChild, BlockReference brParent)
            BlockTableRecord btr = (BlockTableRecord)trParent.GetObject(brChild.BlockTableRecord, OpenMode.ForRead);
            if (btr != null)
                Point3d bockPosition;
                if (brParent != null)
                    bockPosition = TransformPositionRecursively(brParent, trParent, brChild.Position.TransformBy(brParent.BlockTransform));
                else { bockPosition = brChild.Position; }
                Debug.Print(brChild.Name + "  " + bockPosition.X + "  " + bockPosition.Y + "  " + bockPosition.Z + "  " + brChild.Rotation);
                    Entity blockEntity = (Entity)trParent.GetObject(id, OpenMode.ForRead);
                    if (blockEntity is BlockReference)
                        LoopNestedBlocks(trParent, (BlockReference)blockEntity, brChild);
        private static Point3d TransformPositionRecursively(BlockReference btr, Transaction trParent, Point3d nestedPoint)
            try
                BlockTableRecord owner = (BlockTableRecord)trParent.GetObject(btr.OwnerId, OpenMode.ForRead);
                BlockReference parent = null;
                    parent = (BlockReference)trParent.GetObject(parentId, OpenMode.ForRead);
                    break;
                if (parent != null)
                    TransformPositionRecursively(parent, trParent, nestedPoint);
                return nestedPoint;
            catch
Message 15 of 20
BestFriendCZ
ok i found another bug in sampe code up... will be long night:(. i stopped focus on my block and tryed to test function on large structure and position are wrong atleast some of them.
reason is because this row returns colection parent of blockreference and me need only one right parent blockreference for my child blockreference.
Message 16 of 20
BestFriendCZ
i tried modify function but without success.Is there some way how to indetify parent blockreference?
because every parent block contains reference to child block with same name, ID,BlockID but in different position.
Is there a way how to find that right? BTW i use this way because i try to keep the block list as in the old application
            try
                Point3d point3D;
                    BlockTableRecord btr2 = (BlockTableRecord)trParent.GetObject(parent.BlockTableRecord, OpenMode.ForRead);
                    if (btr2 != null)
                        foreach (ObjectId id in btr2)
                                BlockReference testBlocRef = (BlockReference)blockEntity;
                                if (testBlocRef.Id == btr.Id)
                                    point3D = nestedPoint.TransformBy(parent.BlockTransform);
                                    break;
                if (parent != null)
                return nestedPoint;
            catch ()
Message 17 of 20
_gile
Try this one:
                    foreach (Point3d pt in GetNestedPositions(btr, Point3d.Origin, tr))
                        ed.WriteMessage($"\n{pt}");
                tr.Commit();
        private static List<Point3d> GetNestedPositions(BlockTableRecord btr, Point3d position, Transaction tr)
            List<Point3d> positions = new List<Point3d>();
                if (owner.IsLayout)
                    positions.Add(position.TransformBy(br.BlockTransform));
                else
                    positions.AddRange(GetNestedPositions(owner, position.TransformBy(br.BlockTransform), tr));
            return positions;
Gilles Chanteau
GileCAD
GitHub
Message 18 of 20
BestFriendCZ
Hi Gile,
thank you for your sample but i know about this but this is not exactly what i need. I try to explain on the picture.  I have DWG which contains many block like CP130100-07 and these blocks contains for example nested block CP DIGGING HOLE_1. Function returns list of block CP DIGGING HOLE_1 with corect coordination but how can i identify right parent block reference for populate list of block like is on picture. This list contains complete list of block with specific order.
this list is result similar functions as this
                                    LoopNestedBlocks( tr, baseBlock);
        private static void LoopNestedBlocks(Transaction trParent, BlockReference brCurrent)
            BlockTableRecord btr = (BlockTableRecord)trParent.GetObject(brCurrent.BlockTableRecord, OpenMode.ForRead);
            if (btr != null)
                Debug.Print(brCurrent.Name);
                    Entity childEntity = (Entity)trParent.GetObject(id, OpenMode.ForRead);
                    if (childEntity is BlockReference)
                        LoopNestedBlocks(trParent, (BlockReference)childEntity);
Message 19 of 20
BestFriendCZ
i tried use another way transform coordinates from parent to child but nested coordinate are wrong and from child to parent i don't know have how identify parent reference for my sample. I'm getting a little desperate 🙂
                                    List<DrawingElement> test = new List<DrawingElement>();
                                    LoopNestedBlocks(test, tr, baseBlock, new PointTransformed());
                                    foreach (DrawingElement item in test)
                                        //roration is 0 in second level nested block?
                                        Debug.Print(item.BlocName + " " + item.Cordinate.Position.X + " " + item.Cordinate.Position.Y + " " + item.Cordinate.Position.Z + " " + item.Cordinate.Rotation);
        class DrawingElement
            public string BlocName { get; set; }
            public PointTransformed Cordinate { get; set; }
        class PointTransformed
            public Point3d Position { get; set; }
            public Boolean IsNull { get; set; } = true;
            public double Rotation { get; set; }
        private static List<DrawingElement> LoopNestedBlocks(List<DrawingElement> currentList, Transaction trParent, BlockReference brCurrent, PointTransformed pointParent)
            if (btr != null)
                PointTransformed pointCurrent;
                if (!pointParent.IsNull)
                    pointCurrent = new PointTransformed()
                        Position = pointParent.Position.TransformBy(brCurrent.BlockTransform),
                        IsNull = false
                else
                    pointCurrent = pointCurrent = new PointTransformed()
                        Position = brCurrent.Position,
                        IsNull = false
                DrawingElement currentElement = new DrawingElement();
                currentElement.Cordinate = pointCurrent;
                currentElement.BlocName = brCurrent.Name;
                currentElement.Cordinate.Rotation = brCurrent.Rotation;
                currentList.Add(currentElement);
                        LoopNestedBlocks(currentList, trParent, (BlockReference)childEntity, pointCurrent);
            return currentList;
Message 20 of 20
BestFriendCZ
Looks like it works ... i checked on few DWG and it works correct...last problem are rotations. Does anybody know how to get rotation from nested block? because blockreference rotation doesn't have property TransformBy
                                    List<BlockReference> parentReferenceList = new List<BlockReference>();
                                    int level = 0;
                                    LoopNestedBlocks(test, tr, baseBlock, parentReferenceList, ref level);
                                    if (baseBlock.Name == "BaseBlock") /*A$C70C23CFC*/
                                            Debug.Print(item.BlocName + " " + item.Cordinate.Position.X + " " + item.Cordinate.Position.Y + " " + item.Cordinate.Position.Z);
        private static void LoopNestedBlocks(List<DrawingElement> currentList, Transaction trParent, BlockReference brCurrent, List<BlockReference> parentReferenceList, ref int parentLevel)
            try
                if (btr != null)
                    List<DrawingElement> subList = new List<DrawingElement>();
                    int currentBlockLevel = 0;
                    GetCurrentLevel(brCurrent, trParent, ref currentBlockLevel, parentReferenceList);
                    if (currentBlockLevel != parentReferenceList.Count)
                        parentReferenceList.RemoveRange(currentBlockLevel, parentReferenceList.Count - currentBlockLevel);
                    Point3d currentBlockPosition = brCurrent.Position;
                    for (int i = parentReferenceList.Count; i > 0; i--)
                        BlockReference parentBlockRef = parentReferenceList[i - 1];
                        currentBlockPosition = currentBlockPosition.TransformBy(parentBlockRef.BlockTransform);
                        Position = currentBlockPosition,
                        IsNull = false
                        Cordinate = pointCurrent,
                    parentReferenceList.Add(brCurrent);
                    parentLevel = currentBlockLevel;
                            LoopNestedBlocks(currentList, trParent, (BlockReference)childEntity, parentReferenceList, ref parentLevel);
            catch { }
        private static void GetCurrentLevel(BlockReference btr, Transaction trParent, ref int currentLevel, List<BlockReference> parentReferenceList)
            try
                    if (parentReferenceList.Contains(parent))
                        break;
                if (parent != null)
                    currentLevel++;
                    GetCurrentLevel(parent, trParent, ref currentLevel, parentReferenceList);
            catch { }
