TransactionManager.StartTransaction() throws NullReferenceException
adam.krug
Message 1 of 8
adam.krug
Inside of DB.Object_Modified event handler I'm examining the modified object. Sometimes I need to retrieve another object based on an ObjectId, thus I use transaction. 90% of times it works but sometimes TransactionManager.StartTransaction() method throws a NullReferenceExeption internally (stack trace below). Any idea how could I prevent this from happening (is there any property of DBObject, Document or anything else I could use to check if I can safely start a transaction?
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.Runtime.Interop.CheckNull(IntPtr returnValue)
at Autodesk.AutoCAD.ApplicationServices.TransactionManager.StartTransaction()
Eventually I could use a try-catch block but I'm looking for a more efficient way.
Replies (7)
Message 2 of 8
Virupaksha_aithal
Autodesk Support
Autodesk Support
see if "StartOpenCloseTransaction" transaction helps in your case. refer https://adndevblog.typepad.com/autocad/2012/08/the-right-tools-for-the-job-autocad-part-5.html
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
adam.krug
Hi @Virupaksha_aithal ,
In my case it didn't help but still thanks for pointing out on the StartOpenCloseTransaction , very interesting read!
I'm not sure what exactly is causing the problem, seems like the context for starting the transaction is sometimes not valid. Anyways, I decided to change my original approach: during Db_ObjectModified event handler I only add the modified objects on a list and examine them only after a command is finished, using Doc_CommandEnded event handler. Then I also clean the list. Works.
Message 4 of 8
timgrote
I've run into issues where there is no active document, and the code still runs from a palette or other event.
Checking for a null document has helped with that.
Document doc = CAD_App.DocumentManager.MdiActiveDocument;
if (doc == null) return;
Message 5 of 8
adam.krug
Hi @timgrote
In my case the ActiveDoc is not null, I'm getting the null reference exception inside of the StartTransaction() call.
If ActiveDoc was null, I wouldn't be able to even reach StartTransaction()
Message 6 of 8
Alfred.NESWADBA
does your active doc have a valid database? Otherwise it could be the AutoCAD start window.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 8
_gile
The NullReferenceException is probably related to an instance of TransactionManager or the instance of Database (or Document) the TransactionManager is got from.
Try simply doing:
using (var tr = new OpenCloseTransaction())
    // do your stuff with tr here
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
quan_hm
hi @adam.krug ,
Can you make more clear about your approach (or a sample code) about using Doc_CommandEnded event handler. I want to use that to modify object properties after a command finish.
Hoang Minh Quan - Lead Developer
Autodesk Store for IntegaDesign Content
Smart Solutions by IntegaDesign
Plant 3D • CAD Optimization • Automation
