There is something wrong in the intersectwith function, how to deal with this?
stefanveurink68AXD
stefanveurink68AXD
Almost can't imagine it but, but don't see any other expanation:
Explain this:
            Point3dCollection snijpunten = new Point3dCollection();
            bovenaanzicht.IntersectWith(hulplijn1, Intersect.OnBothOperands, snijpunten, IntPtr.Zero, IntPtr.Zero);
            int aantalsnijpunten = snijpunten.Count;
            if (aantalsnijpunten > 0)
                foreach (Point3d snijpunt in snijpunten)
                    double debug = bovenaanzicht.GetDistAtPoint(snijpunt);
I get a 'eInvalidInput' at defining the 'debug double'.
I'm calculating pretty much intersections in my code and suddenly this happens, every time at same moment.
Was having a similar issue a few days ago, couldn't figure it out, so rewrote the whole code in some other way, now this same thing happens again...
Is there a way to solve this?
_gile
This is perhaps an accuracy issue (this may happen if entities are far away from Origin).
You can try this:
Point3d pointOnCurve = bovenaanzicht.GetClosestpointTo(snijpunt);
double delta = snijpunt.GetDistanceTo(pointOnCurve);
double debug = bovenaanzicht.GetDistAtPoint(pointOnCurve);
Gilles Chanteau
GileCAD
GitHub
