The .NET example does not work in dialog form.
Hi everyone,
I am going to run a sample code that generates polylines in the following environment.
[Environment]
VS 2019 communication, ACAD 2018, .NET Framework 4.7.2
[sample code]
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-NET/files/GUI...
I installed objectARX 2018 to add acax22ENU.tlb and axdb22enu.tlb to the reference in Solution Explorer, and added also AcCorMGD.dll, AcCui.dll, AcDbMgd.dll, and AcMgd.dll.
Then I inserted the create polyline example code in the event of button1_Click, which is causing a problem from here.
Private void button1_Click(object sender, EventArgs e)
    Document acDoc = Application.DocumentManager.MdiActiveDocument; // issue. Application is an ambiguous reference between Autodesk.AutoCAD.ApplicationServices.Application and System.Windows.Forms.Application.
So, I avoided the syntax error by explicitly changing it like this:
    Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
However, when I run the application and press button1, error occurs that "Common Language Runtime detected an invalid program." in the modified line.
I would appreciate if you let me know where I made the mistake.
kerry_w_brown
Perhaps try something like this :-
in your using statements add :
using _cadApp = Autodesk.AutoCAD.ApplicationServices.Application;
in your code body use :
var doc = _cadApp.DocumentManager.MdiActiveDocument;
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Thank you for your help.
I modified the code as you suggested.
[statements add]
[code - before]
[code - after]
var acDoc = _cadApp.DocumentManager.MdiActiveDocument;
However, the Common Language Runtime error will still occur when running the application.
There is still a problem in the acDoc variable creation line.
_gile
You did not describe the context the "dialog form" is created.
I suspect it's a Windows form executable application (exe).
The AutoCAD API (accoremgd.dll acdbmgd.dll, acmgd.dll libraries) can only be used in AutoCAD application context, i.e. from a dll netloaded in AutoCAD (see this topic).
You should start from here.
Gilles Chanteau
GileCAD
GitHub
That's right.
I was looking at the example code with a windows form executable application.
Thank you for suggesting the right way.
