Text split
Text split
k005
Advisor Advisor
Message 1 of 9
Text split
k005
Hello everyone !
I am printing a text in the form of 25ø8/10 L=250 on a point using "YaziOlustur" method.
How can I separate the L=250 part while printing it?
well ;
25ø8/10 a DBText L=250 a DBText
25ø8/10 L=250
Replies (8)
Message 2 of 9
HJohn1
"Separate while printing" is not clear, well at least to me. What exactly you are after?
I suppose that you are aware of the String.Split method and regular expressions.  Depending on the string variations, you need to decide which approach is better.  For instance, if your strings values always terminate with the same pattern "L=####" after a blank space, simply use the split method on white space.  If you have more variations, I will suggest to use regular expressions.
Message 3 of 9
k005
acText.SetDatabaseDefaults();
                acText.Position = pointRes.Value;
                acText.Height = YaziYuks;
                acText.TextString = TextVeri;
                acBlkTblRec.AppendEntity(acText);
                tr.AddNewlyCreatedDBObject(acText, true);
                tr.Commit();
this is not a Array. only 1 DBtext object
YaziOlustur creates only one Text at the moment. ( 25ø8/10 L=250 )
My goal is to create two Texts. on the same axis... (
25ø8/10 L=250)
Yes, there is always space. How can I divide from this space?
Message 4 of 9
HJohn1
I have no idea who YaziOlustur is or how his routine works.  I am simply trying to give you some pointers.  If you need to create more than one DBtext, you need to create a loop after you split the string to add the texts.
 string value = "25ø8/10 L=250";
 string[] results = value.Split(" ");
 for (int i = 0; i < results.Length; i++)
      Create the DBtext here
Message 5 of 9
k005
@HJohn1
In my previous message, I showed how the DBtext related to Create-text is created. =
 tr.AddNewlyCreatedDBObject(acText, true); //=  25ø8/10 L=250
I just want to split. so it can't be split without looping?
I guess it won't happen... I have to find another solution.
Thank you so much.
Message 6 of 9
Jeff_M
What is the issue with looping? Something like the following will take your textstring, split in 2, and add 2 DBText objects on the same line. The appears to be exactly what you asked for.
            var TextVeri = "25ø8/10 L=250";
            var strings = TextVeri.Split(' ');
            var width = 0.0;
            foreach (string s in strings)
                var acText = new DBText();
                acText.Position = new Point3d(pointRes.Value.X + width, pointRes.Value.Y, pointRes.Value.Z);
                acText.Height = 2; //I don't know what the YaziOlustur method is
                acText.TextString = s;
                width = acText.GeometricExtents.MaxPoint.X + 2; //determine amount to offset the second text in X direction
            tr.Commit();
Jeff_M, also a frequent Swamper
Message 7 of 9
k005
Thank you so much.
Yes that way... only the second post has a lot of spacing... I think I can figure it out myself.
25ø8/10 L=250
The length of the spaces should be as long as the text.
Message 8 of 9
Jeff_M
the 2 in my width calculation is 2 drawing units. Just make that distance smaller to decrease the spacing.
Message 9 of 9
k005
Yes. I was able to solve that part. Thank you so much. 🤗
