Table object
Table object
ProfWolfMan
Table object
ProfWolfMan
Good Day!
I am trying to create a table with 2rows & 2columns with a title.
I do some search here and google and i can not find perfect instruction about table.
Because now i can not use noofroes & noofcolumns methods.
and also i can not use mytable.cells(row,column).value="xxx".
those are absolute.
Anyone have piece of code to create a simple table using latest api?
It helps more for me.
Thanks & Regards,
G
Hallex
Try this function
        public static void SetCell(Table oTable, int row, int column, string value,
           double height, CellAlignment cellalign)
            //oTable.SetTextString(row, column, value);//<A2010
            oTable.Cells[row, column].TextString = value;//A2010
            // oTable.SetTextHeight(row, column, height);//<A2010
            oTable.Cells[row, column].TextHeight = height;//A2010
            //oTable.SetAlignment(row, column, cellalign);//<A2010
            oTable.Cells[row, column].Alignment = cellalign;//A2010
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
ProfWolfMan
Hi Hallex,
Thanks for your reply.
When i try to attempt table.cells() method following error occurs.
(image attached)
Method not found: 'Autodesk.AutoCAD.DatabaseServices.CellRange
Autodesk.AutoCAD.DatabaseServices.Table.get_Cells()'
I am using AutoCAD2008 & VS2005. Below is a snippet.
'create table
Dim PJtbl As New Table
PJtbl.InsertRows(0, 10, 1)
PJtbl.InsertRowsAndInherit(1, 0, 5)
PJtbl.InsertColumns(0, 25, 1)
'assign value
PJtbl.Cells(0, 0).TextString = rowvalues(0)
Thanks & Regards,
G
Hallex
I haven't have this version on my machine sorry
Try other function from my old project
perhaps it will do your work
     public void FillCell(Table oTable, string value, int row, int column,
           ObjectId id, double height, CellAlignment cellalign, double topmargin, double bottommargin,
            double leftmargin, double rightmargin)
            oTable.SetTextStyle(row, column, id);
            oTable.SetMargin(row, column, CellMargins.Bottom, bottommargin);
            oTable.SetMargin(row, column, CellMargins.Top, topmargin);
            oTable.SetMargin(row, column, CellMargins.Left, leftmargin);
            oTable.SetMargin(row, column, CellMargins.Right, rightmargin);
ProfWolfMan
Sorry!!!
I am out of luck.
API says table.setstring() is obsolute.
I am keep trying to solve it.
Thanks for your valuable time.
Meanwhile, anyone knows to create a simple table & assign values in AutoCAD2011?
Table API changed lot from its previous.
Please share.
Thanks & Regards,
G
From here http://www.theswamp.org/index.php?topic=37061.msg420539#msg420539
Took out tuples and blocks in link works for 2011 and 2012
            [CommandMethod("CreateTable")]
            public void CreateTable()
                Document doc = Application.DocumentManager.MdiActiveDocument;
                Database db = doc.Database;
                Editor ed = doc.Editor;
                using (Transaction trx = db.TransactionManager.StartTransaction())
                    BlockTable bt = db.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                    BlockTableRecord btrMs = (BlockTableRecord)bt[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForRead);
                    Table tbl = new Table();
                    tbl.TableStyle = db.Tablestyle;
                    tbl.Position = Point3d.Origin;
                    TableStyle ts = (TableStyle)trx.GetObject(tbl.TableStyle, OpenMode.ForRead);
                    double txtheight = ts.TextHeight(RowType.DataRow);
                    tbl.Cells[0, 0].TextString = "Title";
                    tbl.InsertRows(1, 1, 1);
                    tbl.Rows[1].Style = "Data";
                    tbl.InsertRowsAndInherit(1, 1, 3);
                    tbl.InsertColumnsAndInherit(1, 0, 1);
                    for (int i = 1; i <= 3; i++)
                        tbl.Cells[i, 0].Contents.Add();
                        tbl.Cells[i, 0].Contents[0].TextString = "dfdrdrrerd";
                        tbl.Cells[i, 1].Value = "hgjhgjjg";
                    tbl.GenerateLayout();
                    btrMs.UpgradeOpen();
                    btrMs.AppendEntity(tbl);
                    trx.AddNewlyCreatedDBObject(tbl, true);
                    trx.Commit();
