Table not updating information
Message 1 of 8
Hey all,
I have been playing with tables in AutoCAD lately and have had mixed results. I can create a table from scratch using code and edit the table. However editing an existing table is a different story. The table will not update at the end with the new information or formatting. The code i have is as follows:
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Try
            Dim selectionres As PromptSelectionResult
            selectionres = ed.SelectImplied
            If (selectionres.Status = PromptStatus.Error) Then
                Dim selectionopt As PromptSelectionOptions
                selectionopt = New PromptSelectionOptions
                selectionopt.MessageForAdding = vbCr + "Select Table to Edit "
                selectionres = ed.GetSelection(selectionopt)
            Else
            If selectionres.Status = PromptStatus.OK Then
                Dim tr As Transaction = doc.TransactionManager.StartTransaction()
                Using tr
                    Dim ids As New ObjectIdCollection(selectionres.Value.GetObjectIds)
                    Dim bt As BlockTable = tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead)
                    Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                    For Each id As Object In ids
                        Dim tb As Table = id.GetObject(OpenMode.ForWrite)
                        Dim numrows As Integer
                        Dim numcol As Integer
                        numrows = tb.Rows.Count
                        numcol = tb.Columns.Count
                        ed.WriteMessage("table name: " + tb.Name.ToString + " Num Columns: " + numcol.ToString + " Num Rows: " + numrows.ToString)
                        ' Use a nested loop to add and format each cell
                        For i As Integer = 1 To numrows
                            For j As Integer = 1 To numcol
                                If tb.Cells(i, 1).Value = "1/1" Then
                                    'tb.Cells(i, j).Borders.Bottom.IsVisible = False
                                    tb.Rows(i).Borders.Top.IsVisible = False
                                ElseIf tb.Cells(i, 1).Value = "1/2" Then
                                    tb.Cells(i, 1).TextString = "new"
                                Else
                                tb.Cells(i, j).Alignment = CellAlignment.MiddleLeft
                            Next
                        Next
                        tb.GenerateLayout()
                        btr.AppendEntity(tb)
                        'tr.AddNewlyCreatedDBObject(tb, True)
                        tr.Commit()
                    Next
                End Using
        Catch ex As Exception
        End Try
The code seems pretty basic and hence i can't figure out what i'm missing. The plan is to get the table edit to work, then add more to the code that will edit the existing table.
any push in the right direction would be appreciated.
Replies (7)
Message 2 of 8
Paulio
You're committing your transaction inside your for/next loop so when it does the loop the second time the transaction will no longer be any good and it'll error to your catch. As the catch is empty it'll just end without showing any error.
Try moving your commit to outside the for/next and see if that makes any difference.
Message 3 of 8
I have not noticed the commit inside the for/next loop, however after moving the tr.commit out of the loop it did not fix the problem. I also added some code to catch the exception and when I did the following was shown in the AutoCAD command line after running the application:
eAlreadyInDb
   at Autodesk.AutoCAD.DatabaseServices.BlockTableRecord.AppendEntity(Entity
entity)
I'm guessing by the code above that the entity already exists, but that is kind of the point of the exercise I would have thought.
Any thoughts?
Message 4 of 8
Paulio
Sorry. Didn't notice that. You don't need to 'appendentity' or do the 'trans.AddNewlyCreatedDbObject' because you're modifying an existing entity. You only need to do that if you're creating a new object (hence the term 'AddNewlyCreatedDbObject'). Just committing the transaction after modifying it will save the changes.
BTW, it's probably better to get the object using the transaction rather than getting it using the GetObject method of the ObjectID.
i.e.
tb = trans.GetObject(id, OpenMode.ForWrite)
 rather than
tb = id.GetObject(OpenMode.ForWrite)
I think I'm right in saying (and hopefully someone will correct me if not) but if you open objects the way you're doing,  then you are responsible for also closing them, which if you don't, could mean you leave objects in open for write status and give you more grief. Using the transaction will handle all that for you.
Message 5 of 8
i.e.
 rather than
ObjectId.GetObject() uses the top Transaction, so there's no problem there.
IOW, these are equiavalent:
   TransactionManager.TopTransaction.GetObject( id....)
   id.GetObject(...)
ObjectId.Open() is the method that opens DBObjects directly without using transactions,
and is where you must call Dispose() on the DBObject, or AutoCAD crashes.
It's actually a bit easier to use id.GetObject() since you don't have to lug around
a Transaction to every place in your code where you open objects. I use it almost
exclusively now, rather than using the Transaction's GetObject(), and find it helps
to simplify a lot of code.
Message 6 of 8
Paulio
So if I've understood correctly:
If I have a sub that starts a transaction then call a function passing an objectid I can use the .GetObject on the ID and that effectively uses the transaction in the calling sub. (?)
Sorry. Just noticed you said 'without transactions'. Does that mean I only need a transaction if I want to save any changes?
Message 7 of 8
ObjectId.GetObject() always uses the Top transaction, and throws
an exception if there are no active transaction.
The 'top' transaction is the one that was most recently started,
regardless of what code started it.
The only way to open objects is directly via ObjectId.Open(), or via
a Transaction. You can use either but should always use transactions
unless there is a good reason to avoid them (there are a few, obscure
reasons, like for example, using transactions at certain times disables
the user's ability to REDO an UNDO).
Message 8 of 8
Paulio
Thanks Tony, that's useful info.
