Table cell text bold
stefan.hofer
stefan.hofer
I have my Table:
AcadTable acTable = new AcadTable();
acTable = thisDrawing.PaperSpace.AddTable(insertPoint, rows, columns, defaultRowHeight, defaultColumnWidth);
acTable.SetTextHeight((int)AcRowType.acTitleRow, 3);
acTable.SetTextHeight((int)AcRowType.acHeaderRow, 2);
acTable.SetTextHeight((int)AcRowType.acDataRow, 2);
acTable.SetTextStyle((int)AcRowType.acTitleRow, "Arial");
acTable.SetTextStyle((int)AcRowType.acHeaderRow, "Arial");
acTable.SetTextStyle((int)AcRowType.acDataRow, "Arial");
acTable.RowHeight = defaultRowHeight;
acTable.Layer = "0";
and can change the text color:
acTable.SetCellContentColor(currentRow, currentColumn, (AcadAcCmColor)myColor);
How can i make the text from a cell or column BOLD ?
_gile
It seems to me you're using the COM/ActiveX API, so all available methods for the AcadTable object ar described >>here<<.
As far as I know, the only way is to force the mtext using format code (see >>here<<😞
acTable.SetTextString(currentRow, currentColumn, 0, "{\\fArial|b1|i0;Your text here);
Gilles Chanteau
GileCAD
GitHub
_Tharwat
Maybe one solution is to wrap the string with the bold codes like this:
"{\\fArial|b1|i0|c0|p34;" MyString "}"
stefan.hofer
I tried this:
string myString = "BoldText";
acTable.SetTextString(currentRow, currentColumn, 0, "{\\fArial|b1|i0|c0|p34;" + myString + "}");
//and
acTable.SetText(currentRow, currentColumn, "{\\fArial|b1|i0|c0|p34;" + myString + "}");
//and
acTable.SetCellValue(currentRow, currentColumn, "{\\fArial|b1|i0|c0|p34;" + myString + "}");
all give me no bold text. It's the normal arial font like in all other cells.
stefan.hofer
Forget my last post, it works fine.
I changed the wrong part in my code....
thank you!
_gile
This works for me:
string yourString = "NormalText";
acTable.SetTextString(currentRow, currentColumn, 0, yourString);
currentRow++;
yourString = "BoldText";
acTable.SetTextString(currentRow, currentColumn, 0, "{\\fArial|b1|c0;" + yourString + "}");
Gilles Chanteau
GileCAD
GitHub
