Statusbar not being added
BrentBurgess1980
BrentBurgess1980
Hi All,
Have some code that adds to the statusbar, but nothing seems to display.
  public void SetPane()
            Document doc = AcApp.DocumentManager.MdiActiveDocument;
            if (doc != null)
                Pane pane = getPane();
                if (pane == null)
                    pane = new Pane();
                    doc.GetStatusBar().Panes.Add(pane);
                pane.Enabled = true;
                pane.Style = PaneStyles.Normal;
                pane.Text = string.Format("Client: TEST");
                pane.ToolTipText = "Displays the current client standards";
                pane.Visible = true;
        private Pane getPane()
            Pane p = null;
            foreach(Pane pane in doc.GetStatusBar().Panes)
                if(pane.Text.Contains("Client:"))
                    p = pane;
                    break;
            return p;
I have a snapshot of the statusbar and it looks like is has added something, but not displaying.
Is there something that I have missed?
Cheers,
Brent
deepak.a.s.nadig
Does changing the way the status bar is added as below help solve your issue ?
Autodesk.AutoCAD.ApplicationServices.Application.StatusBar.Panes.Add(pane);
