startup Sub
startup Sub
Amremad
startup Sub
Amremad
hello every one.
how can i make a sub can load automaticlly when autocad open (load at startup)
_gile
Hi
I'm not certain to uderstand what you mean with: "a sub can load automaticlly when autocad open".
If you want tour DLL to be loaded at startup, you can use the AutoLoader (since A2012) or register your apllication.
if you want some code to be run at startup, see the IExtensionApplication interface.
Gilles Chanteau
GileCAD
GitHub
Amremad
    Implements IExtensionApplication
    Public Sub Initialize() Implements IExtensionApplication.Initialize
        MsgBox("Initialize")
    End Sub
 i found my solution
but  the terminate sub doesn't work
   Public Sub Terminate() Implements IExtensionApplication.Terminate
        MsgBox("Terminate")
    End Sub
