Setting Table Margins
I am trying to set my tables margins. My line to do that is:
atsHeadTable.SetMargin(CellMargins.Left, 0.03, RowType.DataRow)
But I get an error when doing this.  I think I have the stylename in the command wrong.  What do I put in there?
I also used the command:
MyTable.Cells(0, 0).Borders.Horizontal.Margin = 0.03
This works but I have to set it for each cell.
Hallex
Try to set to exact size the height of the table before
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Hallex
Here is a quick example
        Public Shared Sub SetMarginsToTable()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Using tr As Autodesk.AutoCAD.DatabaseServices.Transaction = doc.Database.TransactionManager.StartTransaction()
                Dim peo As PromptEntityResult = ed.GetEntity(vbCr & "Select table >>")
                Dim ent As Entity = CType(tr.GetObject(peo.ObjectId, OpenMode.ForWrite), Entity)
                Dim tb As Table = TryCast(ent, Table)
                'particular cells only:
                'Dim row As Integer = 2, column = 1
                'tb.SetMargin(row, column, CellMargins.Left, 0.03)
                'entire tatble:
                tb.HorizontalCellMargin = 0.075
                tb.VerticalCellMargin = 0.03
                tr.Commit()
                ''check changes
                MsgBox(String.Format("Vertical margins: {0}" & vbCr & "Horizontal margins: {1}", tb.VerticalCellMargin, tb.HorizontalCellMargin))
            End Using
        End Sub
~'J'~
Thanks that helped.  I did try that when I started to make my program and received an error. The error must have came from somewhere else.  This now works.
Hallex
You're welcome
Cheers 🙂
~'J'~
