Setting current viewport
How can I activate a particular paperspace viewport using VB.Net? In VBA,
the document object had an "Active Viewport" property and you just did
ActiveDocument.ActiveViewport = myvport.
I can't find a similar property in VB.Net.
I've found the "CurrentViewportObjectID" as a property of the document
editor, but it's a read-only property and I can't find out where it gets
set.
Can anyone guide me? I've searched the discussion groups and Google, but
can't find anything.
Thanks in advance. . .
bikelink
I have the same problem. The docs isn't correct. the property about the viewport not exists.
How can I set the current viewport in paper space (layout) without use property Number?
Still no answer to this question? I believe this link has some relevance but the solution is still not intuitive. Well for me.
http://discussion.autodesk.com/forums/thread.jspa?threadID=455076
Have you found the answer?
That code doesn't show the solution.
The only solutions are to P/Invoke acedSetCurrentVPort() or use the CVPORT
system variable.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:[email protected]...
http://discussion.autodesk.com/forums/thread.jspa?threadID=455076 Have you
found the answer?
Thanks Tony for the direction. CVPORT? could not get it to work (send commands to command line) except in the modelspace tab. In any paperspace tab the command itself CVPORT does not work?? So I used the p/invoke acedSetCurrentVport() method. there were two great blogs I referenced.
Kean Walmsleys described a method for extracting the function line from the acad.exe file:
http://through-the-interface.typepad.com/through_the_interface/2006/07/calling_objecta.html
And using the afore mentioned example as guide:
http://discussion.autodesk.com/forums/thread.jspa?messageID=6123415?
It seems to be working, (not pretty, but moving forward!):
'pinvoke acedSetCurrentVport function out of acad.exe file
<DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, _
EntryPoint:="?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")> _
Public Shared Function acedSetCurrentVPort(ByVal AcDbVport As IntPtr) As IntPtr
End Function
///////////////////////////////// after switching layout tabs to desired and zoom extents ///////////////////////////////////////////////////////////////
'*************************************** find viewport and activate **************************************
Dim ed As Editor = ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = HostApplicationServices.WorkingDatabase
Try
Dim layoutManager__1 As LayoutManager = LayoutManager.Current
layoutManager__1.CurrentLayout = "Floor Plan 100"
Dim vpXdim As String = ("18") 'viewport desired's CenterPoint X value
Dim layout As Layout = TryCast(myTrans.GetObject(layoutManager__1.GetLayoutId _
("Floor Plan 100"), OpenMode.ForRead), Layout)
Dim objectIdCollection As ObjectIdCollection = layout.GetViewports()
For Each VportObjId As ObjectId In objectIdCollection
Dim Vport As Viewport = DirectCast(myTrans.GetObject(VportObjId, OpenMode.ForWrite), Viewport)
' Dim AcDbVport As AcDbViewport = DirectCast(myTrans.GetObject(Vport, OpenMode.ForWrite), AcDbViewport)
Dim X As String = Vport.CenterPoint.X.ToString
If vpXdim = X Then 'center point X value = given X value > this is desired viewport
//////////////////////////////////////////////// heres the gem!! //////////////////////////////////////////////////////////
acedSetCurrentVPort(Vport.UnmanagedObject) 'set Vport as current viewport
myDWG.Editor.SwitchToModelSpace() 'switch to modelspace
Exit For
Next
Catch ex As System.Exception
ed.WriteMessage(vbLf & ex.Message)
ed.WriteMessage(vbLf & ex.StackTrace)
End Try
thanks again Tony, learned a bunch, now how the #$%#$% do you get this to format in a post?
