set transparency to layer - other result then input
jan_tappenbeck
jan_tappenbeck
hi !
i want to set value of transparency to layer.
my function is
 Public Function ChangeTransOfLayer(ByVal LayerFilter As String, _
                                       ByVal LyTransValue As Integer, _
        Optional ByRef Log As String = "",
                                          Optional ByRef Execute As Boolean = True) As Boolean
        'http://ma22-wiki-001/eblwiki/index.php?title=Acad_(Klasse_von_EBL.Service)#ChangeTransOfLayer
        AcReInit()
        If LayerFilter.Length = 0 Then
            Log += "**** Fehler - kein Layer definiert" & vbCrLf
            Return False
        ' Todo - wenn einmal ein Filter in der Layerliste verfügbar ist
        Dim Layers As List(Of String) = GetLayerList(LyFilter:=LayerFilter, IgnoreXrefLayer:=True)
        Try
            Using tr As Transaction = _Database.TransactionManager.StartTransaction()
                '' Open the Layer table for read
                Dim acLyrTbl As LayerTable
                acLyrTbl = tr.GetObject(_Database.LayerTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead)
                If Execute = False Then _Editor.WriteMessage("** Befehlssimulation **" & vbCrLf)
                ''For Each sLayerName As String In Layers
                Dim sLayerName As String = LayerFilter
                Try
                    If Execute = True Then
                        If acLyrTbl.Has(sLayerName) = True Then
                            '' Open the layer if it already exists for write
                            Dim acLyrTblRec As LayerTableRecord = tr.GetObject(acLyrTbl(sLayerName), _
        Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
                            '' Set the color of the layer
                            acLyrTblRec.Transparency = New Autodesk.AutoCAD.Colors.Transparency(CByte(LyTransValue))
                    Else
                        _Editor.WriteMessage("Layer " & sLayerName & " - Farbe geändert in " & LyTransValue.ToString & " ..." & vbCrLf)
                Catch ex As Exception
                    Log += "unerwarteter Fehler in EBL.Service > Acad > ChangeTransOfLayer - Loop" & vbCrLf & _
                        "Color:= " & LyTransValue.ToString & vbCrLf & _
                        "LayerFilter:= " & LayerFilter & vbCrLf & _
                        "Log:= " & Log & vbCrLf & _
                                "Execute:= " & Execute.ToString & vbCrLf & _
                    ex.ToString()
                End Try
                ''                Next
                tr.Commit()
            End Using
                "Layername:= " & LayerFilter & vbCrLf & _
            ex.ToString()
            Return False
        End Try
        Return True
    End Function
when i run the function by LyTransValue=80 the transparency in layer-Manager will be 68 !!!
why?? could someone help to me?
regards Jan
_gile
The argument for the Transparency ctor is a byte (in the range [0-255]) representing the Apha value in the ARGB color encoding where 255 means 100% transparency.
So if you want to set 80% transprency you have to compute 255 * 20% as a byte value:
acLyrTblRec.Transparency = New Autodesk.AutoCAD.Colors.Transparency(CByte(255 * (100 - LyTransValue) / 100.0)
Gilles Chanteau
GileCAD
GitHub
_gile
Closer to the way AutoCAD works:
byte alpha = (byte)(255 * (100 - transparencyValue) / 100);
I'm not very cumfortable with VB, but I think the VB equivalent should be:
Dim alpha As Byte = CByte(255 * (100 - transprencyValue) \ 100)
Gilles Chanteau
GileCAD
GitHub
