Set color of subdmesh faces/verts using .net?
JamesMaeding
Advisor Advisor
JamesMaeding
I have realized that using a subdmesh is way way faster than 3d faces for a tin surface.
I have things working nicely now to create the mesh, but have only seen this post on setting colors:
http://adndevblog.typepad.com/autocad/2013/09/vertex-color-for-a-subdmesh.html
It uses the AcDbSubDMesh::setVertexColorArray method, which I do not see for .net.
I do see SetSubentColor(Autodesk.AutoCAD.DatabaseServices.SubentityId, Autodesk.AutoCAD.Colors.Color),
but I have never dealt with the subentities of a mesh.
I would guess if I don't have a setcolorarray method, I must do each vertex color one by one.
That is no problem, but checking if there is a better way in .net.
thanks
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
JamesMaeding
duh, just saw property VertexColorArray.
was too focused on the set methods...
