Selectionset using filters
how to make selection set using filters as we will be doing in auotcad VBA similary i need to make selection set using vb.net Message was edited by: Ramya
This one looks for blocks on a layer.
ed.select...
where ed = autodesk.autocad.editor
Public Sub TestSelectionSet()
Using trans As Transaction = db.TransactionManager.StartTransaction
Try
Dim psr As PromptSelectionResult
Dim ss As SelectionSet
Dim oids As ObjectIdCollection
Dim ent As Entity
Dim oid As ObjectId
Dim br As BlockReference
Dim filter(1) As TypedValue
filter(1) = New TypedValue(DxfCode.Start, "INSERT")
filter(0) = New TypedValue(DxfCode.LayerName, "FLOOR 1")
Dim sf As New SelectionFilter(filter)
psr = ed.SelectCrossingWindow(New Point3d(0, 0, 0), New Point3d(4, 4, 0), sf)
ss = psr.Value
If ss.Count > 0 Then
oids = New ObjectIdCollection(ss.GetObjectIds)
For Each oid In oids
ent = oid.GetObject(OpenMode.ForRead)
If TypeOf ent Is BlockReference Then
br = CType(ent, BlockReference)
'Debug.Print(br.Name)
Next
Catch ex As System.Exception
MsgBox(ex.ToString)
Finally
trans.Dispose()
End Try
End Using
End Sub
Thanku very much
