Scale Point with Reference Point
SRSDS
Advisor Advisor
SRSDS
Is there a simple way to scale a point based on a reference point?
I would like to scale the vertices of a selected MLeader if the Cannoscale is changed.
A part of the problem is how to determine the scaling required based on the old and new Cannoscales.
Dim ml As MLeader = DirectCast(trans.GetObject(ObjID, OpenMode.ForWrite), MLeader)
Dim m_leaderLineIndex As Integer = 0
Dim pnt1 As Point3d = ml.GetFirstVertex(m_leaderLineIndex)
Dim pnt2 As Point3d = ml.GetLastVertex(m_leaderLineIndex)
'pnt2 = pnt2.scaleby(??,pnt1)
ml.SetLastVertex(m_leaderLineIndex, pnt2)
SRSDS
Sorry, I think I worked it out
Dim CurrentScaleValue = db.Cannoscale.Scale 'Is the old Scale
Dim NewScaleValue = db.Cannoscale.Scale 'After it's changed
pnt2 = pnt2.ScaleBy(CurrentScaleValue / NewScaleValue, pnt1)
