Save in AcCoreConsole
wesbird
wesbird
  I plan to migrate some functions from AutoCAD to AcCoreConsole. now I have to problem to save the drawing.
  here is the original code works in AutoCAD, I cannot make it compile with AcCoreConsole. I think it must be related to AcMgd.dll.
AcadDocument acadDoc = DocumentExtension.GetAcadDocument(Active.Document) as AcadDocument;
acadDoc.Invoke("Save", new object[0]);
  so I change the code to:
Application.DocumentManager.MdiActiveDocument.Database.SaveAs(fileName, version);
  then I got error message:
eFileSharingViolation
 after this change code to:
Active.Database.Save();
  then error message change to
eFileInternalErr
  What should I do?
Thank you so much for your help
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
jeff
You cant use any any functions defined in Acmgd.dll assembly with core console. Only Accoremgd.dll and AcDbMgd.dll with core console.
The eaisest way would be to remove reference to Acmgd.dll so you be sure it will work with core console.
You can also find your answers @ TheSwamp
So, from what I understand acCodeConsole would save the dwg file automatically when the script ends?
Would also terminate itself or should I kill the process?
What if I want to perform operations that don't require a file save, like a plot. May I instruct acCoreConsole to exit without saving? Saving large drawings can be very time consuming...
Just moving my first steps with acCoreConsole... too bad there is still no documentation after almost two years from its presentation to the community...
The fear here is to invest lot of time and maybe this feature will be completely changed or even removed...
