Save a password protected drawing without password with VB.NET
our drawings are protected by a password.
We have a VB.NET programm to export a drawing without password.
Dim securityPar As New SecurityParameters(Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing)
doc.Database.SaveAs("C:\Temp\Test.DWG", False, DwgVersion.Current, securityPar)
doc.CloseAndSave("C:\Temp\Test.DWG")
In AutoCAD Architecture 2009 (Win XP) it works fine.
In AutoCAD Architecture 2011 (Win 7) the drawing is still password protected.
Thank you for help,
Udo
Alexander.Rivilis
With help of ObjecARX (native) you can clear password protection: http://forums.autodesk.com/t5/Autodesk-ObjectARX/any-way-to-remove-password-from-a-dwg/m-p/3429797#M...
I've not found corresponding method AutoCAD .NET API. IMHO you have to P/Invoke setSecurityParams method.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Alexander.Rivilis
Try this code (minimum testing with AutoCAD 2012 x86):
using System;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(Rivilis.ClearPassword))]
namespace Rivilis
    // This class is instantiated by AutoCAD for each document when
    // a command is called by the user the first time in the context
    // of a given document. In other words, non static data in this class
    // is implicitly per-document!
    public class ClearPassword
        [StructLayout(LayoutKind.Sequential)]
        // From dbsecurity.h
        public struct SecurityParams
            public uint cbSize;
            public uint ulFlags;    // see enum above for flag values
            // data relevant to password protection
            public string wszPassword;
            public uint ulProvType;
            public string wszProvName;
            public uint ulAlgId;        // SECURITYPARAMS_ALGID_RC4
            public uint ulKeyLength;
            // data relevant to digital signatures
            public string wszCertSubject;
            public string wszCertIssuer;
            public string wszCertSerialNum;
            public string wszComment;
            public string wszTimeServer;
        [DllImport("acdb18.dll", CallingConvention = CallingConvention.ThisCall,
            EntryPoint = "?setSecurityParams@AcDbDatabase@@QAE_NPBUSecurityParams@@_N@Z")]
        static extern private bool setSecurityParamsX32(IntPtr db, ref SecurityParams pSecParams, bool bSetDbMod = true);
            EntryPoint = "?setSecurityParams@AcDbDatabase@@QEAA_NPEBUSecurityParams@@_N@Z")]
        static extern private bool setSecurityParamsX64(IntPtr db, ref SecurityParams pSecParams, bool bSetDbMod = true);
        static public bool setSecurityParams(Database db, ref SecurityParams parms, bool bSetDbMod = true)
            if (IntPtr.Size == 4) return setSecurityParamsX32(db.UnmanagedObject, ref parms, bSetDbMod);
                     else         return setSecurityParamsX64(db.UnmanagedObject, ref parms, bSetDbMod);
        [CommandMethod("ClearPWD", CommandFlags.Modal)]
        public void ClearPWD()
            Database db = HostApplicationServices.WorkingDatabase;
            SecurityParams parms = new SecurityParams();
            parms.cbSize = (uint)Marshal.SizeOf(parms);
            parms.ulFlags = 0; // Clear security flag
            setSecurityParams(db, ref parms);
For VB.NET you can convert C# code: http://www.developerfusion.com/tools/convert/csharp-to-vb/
Expert Elite Member
Hello Alexander,
thank you! It works very fine in AutoCAD Architecture 2011.
Udo
