Running .NET from CAD
How do I run VB.NET from AutoCAD?
-J
Netload would be the main command then you need to select the dll file.
alexandrescoelho
How can I run a dll from a stand alone .NET app inside AutoCad 2008 at runtime?
Alexandre S. Coelho
Make the DLL a COM server, and use the COM GetInterrfaceObject() method to load it.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5878606@discussion.autodesk.com...
Alexandre S. Coelho
alexandrescoelho
Hi Tony,
Ok, I need to know if can I execute a dll by sendcommand() loading then and without open autocad interface. I'm setting a AcadApplication.visible = false. No metter if I set it true or false when the sendcommand runs the autocad interface appears anyway. Did you solve any problem like this?
Thanks in advance
