Rotate OLE Object in Autocad Using C#
nathan307
Message 1 of 1
nathan307
Dear Friends,
    I want to Insert An Image as OLE Object and Rotate the Object with respect to the given Angle,I know there no  Rotate Property to the OLE object.
Is there any another Posibilities to Rotate OLE object(Image)...
If Any Posibities explain it through the code.
Note: I want to Insert OLE object because of there is no necessary to Keep the image at the Machine wherever we are Going to use...
  Thank you Friends..
With regards,
nathan307
Replies (0)
