Rotate block with the reference line
kmkxperia
kmkxperia
I am able to rotate the Block but I want the reference line to be shown when I am rotating same as it is shown During Rotate command.
Attached video I run my command and for second I use the rotate command.
[CommandMethod("TestRotation")]
public static void TestEntityJigger5_Method()
    Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
    Database db = HostApplicationServices.WorkingDatabase;
    PromptEntityResult selRes = ed.GetEntity("Pick a block:");
    if (selRes.Status == PromptStatus.OK)
        using (Transaction tr = db.TransactionManager.StartTransaction())
            BlockReference ent = tr.GetObject(selRes.ObjectId, OpenMode.ForWrite) as BlockReference;
            if (ent != null)
                using (Transaction tr1 = db.TransactionManager.StartTransaction())
                    ent.Highlight();
                    tr1.Commit();
                if (BlockRotating.Jig(ent))
                    tr.Commit();
                else
                    tr.Abort();
public class BlockRotating : EntityJig
    #region Fields
    public int mCurJigFactorNumber = 1;
    private double mRotation = 0.0;    // Factor #1
    #endregion
    #region Constructors
    public BlockRotating(Entity ent)
        : base(ent)
    #endregion
    #region Overrides
    protected override bool Update()
        switch (mCurJigFactorNumber)
            case 1:
                (Entity as BlockReference).Rotation = mRotation;
                break;
            default:
                return false;
        return true;
    protected override SamplerStatus Sampler(JigPrompts prompts)
            case 1:
                JigPromptAngleOptions prOptions1 = new JigPromptAngleOptions("\nBlock rotation angle:");
                prOptions1.BasePoint = (Entity as BlockReference).Position;
                prOptions1.UseBasePoint = true;
                PromptDoubleResult prResult1 = prompts.AcquireAngle(prOptions1);
                if (prResult1.Status == PromptStatus.Cancel) return SamplerStatus.Cancel;
                if (prResult1.Value.Equals(mRotation))
                    return SamplerStatus.NoChange;
                else
                    mRotation = prResult1.Value;
                    return SamplerStatus.OK;
            default:
                break;
    #endregion
    #region Method to Call
    public static bool Jig(BlockReference ent)
        try
            BlockRotating jigger = new BlockRotating(ent);
            PromptResult pr;
            do
                pr = ed.Drag(jigger);
                jigger.mCurJigFactorNumber++;
            } while (pr.Status != PromptStatus.Cancel &&
                        pr.Status != PromptStatus.Error &&
                        pr.Status != PromptStatus.Keyword &&
                        jigger.mCurJigFactorNumber <= 1);
            return pr.Status == PromptStatus.OK;
        catch
            return false;
    #endregion
What I am Expecting
_gile
Add an option to the JigPromptAngleOptions:
prOptions1.Cursor = CursorType.RubberBand;
Gilles Chanteau
GileCAD
GitHub
