Ribbon example
Ribbon example
Message 1 of 16
Ribbon example
Hi
If someone have example how to add ribbon with .net, in autocad 2010,
please to post.
Best regards,
Danijel Ivankovic
Replies (15)
Message 2 of 16
Kevin.Bell
I too would be very interested in this...
Message 3 of 16
http://through-the-interface.typepad.com/through_the_interface/2008/04/the-new-ribbonb.html
Message 4 of 16
Kevin.Bell
That link is for a 2009 ribbon example, the 2010 ribbon has been reworked as is different (apparently)
Message 5 of 16
try it
Message 6 of 16
Search google for this: AutoCAD .NET: Developing a User Interface
I sat in on the webcast Aug. 20, 2009. It was good.
Message 7 of 16
Kevin.Bell
Can anyone download the webcast? When I tried I was asked for a logon...
Message 8 of 16
Kevin.Bell
Did it cover specifically info about loading a CUIx file and added a tab to the ribbon with .net - that would be the holy grail for me 🙂
Message 9 of 16
Did you try from this link?
http://through-the-interface.typepad.com/through_the_interface/2009/08/free-webcast-autocad-net---developing-a-user-interface.html
Click on "for download (20.3 MB)".
wrote in message news:6250683@discussion.autodesk.com...
Message 10 of 16
Kevin.Bell
That worked - Thanks.
Our of interest, I saw that the presenter is using Visual Studio 2005 and has a template for AutoCAD called "AutoCAD Managed c# Project" - do you know where these templates can be obtained from?
Cheers.
Message 11 of 16
arcticad
http://www.adskconsulting.com/adn/cs/api_course_sched.php
(defun botsbuildbots() (botsbuildbots))
Message 12 of 16
johnds
I have tried it, it does not work in 2010, Ribbon has changed, quite a bit...so dont even try it!
Message 13 of 16
Kevin.Bell
Does anyone know what API control the ribbon in AutoCAD 2010.
I can find AdWindows.dll, but AcRibbon.dll seems to have gone from this release...
Message 14 of 16
Thanks all on reply!
But, I still can't find ribbon example for autocad 2010.
API for ribbons on acad2009 and acad2010 are changed.
Best regards,
Danijel Ivankovic
Message 15 of 16
Kevin.Bell
Heres a good one:
Under the Course drop down select "AutoCAD 2010 API for CUIX
Message 16 of 16
Thank you archie776!
Best regards,
Danijel Ivankovic
