returning the value of an angle.
ganderson
ganderson
I have a code snipet that displays the angle from the X axis for a line:
public static void AngleFromXAxis()
            Point2d pt1 = new Point2d(2, 5);
            Point2d pt2 = new Point2d(5, 2);
            Application.ShowAlertDialog("Angle from XAxis: " +
                                        pt1.GetVectorTo(pt2).Angle.ToString());
                                         pPtRes = acDoc.Editor.GetPoint(pPtOpts);
is there a way to capture that value in my  program
something like:
    double myAngle = ...?
                   ~Giovonnae
kerry_w_brown
something like:
                   ~Giovonnae
Yes, there is.
What have you tried ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
ganderson
I find your reply most unhelpful.
kerry_w_brown
That's a pity, because if you'd stopped to think about it you have the answer in your own posted code snippet.
ganderson
not helping!
kerry_w_brown
This :
ganderson
Thank you.
