Resetting Z Point coordinates
k005
Advisor Advisor
Message 1 of 16
k005
Hello friends;
I want to set the Z values ​​of all objects in the drawing to 0. But I think there is an error somewhere in this code. It does not give 0 to Z values.
Thanks in advance to the helpful friend.
 private void btnMesleki_Click(object sender, EventArgs e)
            this.Close();
                // Aktif belgeyi al
            Aapp.Document doc = aCap.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            // Kullanıcıdan nesneleri seçmesini iste
            PromptSelectionResult selRes = ed.GetSelection();
            if (selRes.Status != PromptStatus.OK)
                ed.WriteMessage("Seçim iptal edildi veya hatalı.");
                return;
            // Seçilen nesneleri al
            using (Transaction trans = db.TransactionManager.StartTransaction())
            using (Aapp.DocumentLock docLock = Adoc.LockDocument())
                SelectionSet selSet = selRes.Value;
                foreach (ObjectId objId in selSet.GetObjectIds())
                    Entity ent = trans.GetObject(objId, Adb.OpenMode.ForWrite) as Entity;
                    if (ent != null)
                        // Z koordinatını sıfırla
                        ent.TransformBy(Matrix3d.Displacement(new Vector3d(0, 0, -ent.GeometricExtents.MinPoint.Z)));
                // İşlemleri tamamla
                trans.Commit();
            // Ekrana yazı bas
            ed.WriteMessage("Seçilen nesnelerin Z koordinatları sıfırlandı.");
Replies (15)
Message 2 of 16
ActivistInvestor
See this post
Message 3 of 16
k005
How do we integrate it into the code I gave above?
Message 4 of 16
ActivistInvestor
It is an extension method. You just add it to your code file and then call it like it was a method of the Entity class.
<snip>
if (ent != null)
   // Z koordinatini sifirla
   ent.TranslateToXYPlane();
<snip>
Message 5 of 16
k005
It's busy... I'll try. Thank you.
Message 6 of 16
k005
Cannot be accessed due to protection level. I'm getting the error.
Message 7 of 16
norman.yuan
AcRx means Autodesk.AutoCAD.Runtime
Norman Yuan
Drive CAD With Code
Message 8 of 16
k005
Ok. Solution?
Message 9 of 16
kerry_w_brown
@k005
The immediate solution is attached.
The long term solution is to study.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 10 of 16
k005
Thank you. I didn't notice...
* Isn't there a much shorter ready-made code?
It will only give zero value to the Z points of 2D objects. will reset.
Thanks.
Message 11 of 16
kerry_w_brown
Perhaps have a look at this:
https://forums.autodesk.com/t5/net/setting-z-value-to-0-in-all-objects-in-a-drawing/m-p/11685654/hig...
added:
You really need to provide more information about your problems.
happy new year
Message 12 of 16
ActivistInvestor
The code that I posted will only move objects so that the bottom of their bounding box is in the XY plane.
That makes the assumption that they are 2 dimensional objects that are parallel to the XY plane. If that's not the case then you need to be more specific about exactly what it is you are trying to do and what types of objects you are dealing with.
Message 13 of 16
k005
What I want to do is to set the Z point value of objects such as Line, polyline, circle, mline, Text, Mtext to zero. If it's already zero, it won't do anything.
for example a Line object. 500 units and at an angle of 14 degrees. Z1: 18 ,Z2: 35 change it to Z1: 0 , Z2: 0...
Message 14 of 16
k005
I added the class here. In the file I added below, it resets the Z value of only Circle objects. Other Line objects do not reset.
* I tried it in text and points. They also reset. OK.
Message 15 of 16
_gile
For curves that aren't parallel to the XY plane, you can try the Curve.GetOrthoProjectedCurve method.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 16 of 16
k005
OK, let me investigate. Thank you.
