Reload Linetype
Reload Linetype
David_Prontnicki
Message 1 of 9
Reload Linetype
David_Prontnicki
Hi All,
Is it possible to reload a linetype without having to use the send command method. I am familiar with Dev Blogs solution for this but I am curious if it can be done without the send command method. This is what I have so far:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Public Class AutocadService
    Implements IAutocadService
    Public Sub LoadLinetype(ByVal selectedLineTypeName As String, ByVal lineTypeFile As String) Implements IAutocadService.LoadLinetype
        Try
            Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Dim acLineTypTbl As LinetypeTable
                acLineTypTbl = acTrans.GetObject(acCurDb.LinetypeTableId, OpenMode.ForRead)
                If acLineTypTbl.Has(selectedLineTypeName) = True Then
                    'reload linetype somehow
                    Dim frmMessageBox As New frmMessageBox
                    frmMessageBox.lblHeader.Text = "Linetype Loader"
                    frmMessageBox.lblMessageTitle.Text = "Linetype Loaded Successfully!"
                    frmMessageBox.lblMessageBody.Text = "The selected linetype, " & selectedLineTypeName & ", has been re-loaded in the drawing."
                    frmMessageBox.picIcon.Image = My.Resources.msbComplete
                    frmMessageBox.ShowDialog()
                ElseIf acLineTypTbl.Has(selectedLineTypeName) = False Then
                    acCurDb.LoadLineTypeFile(selectedLineTypeName, lineTypeFile)
                    frmMessageBox.lblMessageBody.Text = "The selected linetype, " & selectedLineTypeName & ", is now available in the drawing."
                acTrans.Commit()
            End Using
        Catch ex As Exception
            frmMessageBox.lblMessageTitle.Text = "Linetype Loading Failed!"
            frmMessageBox.lblMessageBody.Text = "Ensure you are using a proper drawing and/or the existing text styles are loaded."
            frmMessageBox.picIcon.Image = My.Resources.msbError
        End Try
    End Sub
End Class
If the line type exists it errors out. I want it to just reload it.
Replies (8)
Message 2 of 9
ambrosl
I don't have a direct example in VB.NET for this, but it should be similar to the concepts shown in this ObjectARX example (https://adndevblog.typepad.com/autocad/2015/03/reloading-linetype-from-file.html).  That is basically creating a new database and loading the linetype into that database, and then copying the linetype from the new database into the database of the current drawing.
An example of copying objects from one database to another database with VB.NET can be found here (https://help.autodesk.com/view/OARX/2020/ENU/?guid=GUID-E02A8AAF-61FF-4C72-8960-0AEEBBEC2594).
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
Message 3 of 9
David_Prontnicki
Thank you for the reply, but I am having hard time understanding that code and converting it to VB. I'm assuming that is C#, but it does not convert in any online converter and even with my basic knowledge of and ability to read C# I am having a hard time making heads or tails of it. Any help would be greatly appreciated.
Message 4 of 9
David_Prontnicki
@ambrosl
I want to make sure I am understanding you correctly: "That is basically creating a new database and loading the linetype into that database, and then copying the linetype from the new database into the database of the current drawing."
So I create a new database (acLtDbNew), load the linetype I want re-loaded (linetypeToReload) into this new database (acLtDbNew), then copy (linetypeToReload) from (acLtDbNew) to the existing database (acLtDb)?
By doing this it forces a reload?
Or do you mean:
Create a new database (acLtDbNew), load the linetype I want re-loaded (linetypeToReload) into this new database (acLtDbNew), then copy ALL the other linetypes (linetypesExisting) from the existing database (acLtDb) into the new database (acLtDbNew) and discard the old database (acLtDb)?
Message 5 of 9
ambrosl
The first, as long as you are using the Replace flag when cloning the linetype it should replace the definition in the existing drawing.  You may need to force an update on the drawing as well afterwards.   I have only personally done this with Dimension Styles and Layers stored in a CAD Standards (DWS) file and brought/updated them into my current drawing, not Linetypes though the concept should be the same.  If I get a bit of time today, I will try to create a code sample that does this.  Sorry, I have been a bit busy with the AutoCAD 2021 release.
Lee Ambrosius
Message 6 of 9
David_Prontnicki
@ambrosl
No problem I completely understand. Below is what I came up with and it appears to be working, I need to do some more testing to be sure. I ending up having to load some text styles into the temp database for some of the linetypes to load, that is the CreateExistingTextStyle and CreateProposedTextStyle you see. What do you mean by force an update to the drawing? Also what is the DeferTranslation as Boolean at end of WblockCloneObjects do? Should that be true or false for what I am doing?
Also, thank you very much for all your help so far. I got a lesson in C++ as well. 😊
    Public Sub ReloadLinetype(ByVal selectedLineTypeName As String, ByVal lineTypeFile As String, ByVal acCurDb As Database)
        Try
            Using acTempDb As Database = New Database(True, True)
                CreateExistingTextStyle(acTempDb)
                CreateProposedTextStyle(acTempDb)
                acTempDb.LoadLineTypeFile(selectedLineTypeName, lineTypeFile)
                Using acTempTrans As Transaction = acTempDb.TransactionManager.StartTransaction()
                    Dim acTempLineTypeTbl As LinetypeTable = CType(acTempTrans.GetObject(acTempDb.LinetypeTableId, OpenMode.ForRead), LinetypeTable)
                    Dim acTempLineTypeId As ObjectId = acTempLineTypeTbl(selectedLineTypeName)
                    Dim acTempLineTypeObjIdColl As New ObjectIdCollection
                    acTempLineTypeObjIdColl.Add(acTempLineTypeId)
                    Dim acIdMap As IdMapping = New IdMapping()
                    acCurDb.WblockCloneObjects(acTempLineTypeObjIdColl, acCurDb.LinetypeTableId(), acIdMap, DuplicateRecordCloning.Replace, True)
                    acTempTrans.Commit()
                End Using
            End Using
        End Try
    End Sub
Message 7 of 9
ambrosl
I didn't run the code, but it looks like it follows the correct logic.
The Defer Translation flag affects when objects are copied if they are needed but not part of the ID array is my understanding.  You can find out more information about defer translation here:
https://help.autodesk.com/view/OARX/2021/ENU/?guid=GUID-8A769B63-F192-4235-82B3-0CA2F3BBDFFD
Lee Ambrosius
Message 8 of 9
David_Prontnicki
@ambrosl
Thank you again! I really appreciate it. Just one last question, what did you mean by force an update to the drawing? A regenall or something completely different?
Message 9 of 9
does reloadlinetype works?
it doesn't work in my computer CAD2018.
using acCurDb.WblockCloneObjects(acTempLineTypeObjIdColl, acCurDb.LinetypeTableId(), acIdMap, DuplicateRecordCloning.Replace, True)
 cad crashes
using acCurDb.WblockCloneObjects(acTempLineTypeObjIdColl, acCurDb.LinetypeTableId(), acIdMap, DuplicateRecordCloning.Replace, false)
 cad doesn't crashes, but the linetype has no reload.
When I monitored acIdMap, I found that only one member has cloned,but the member isn't the linetype
