Relative Path problem
I have problem with the relative path in code to find a file.  The first time it works. In the same AutoCAD session, the second time, the path changes to C:\Users\xyz\AppData\Roaming\Autodesk\AutoCAD 2012 - English\R18.2\enu. Is there any solution to this problem please?
Keith.Brown
Can you post the offending code?  Difficult to diagnose without any code to see what is going on.
