Region creates another instance of polygon
Hi, I'm using this code below to create a region of an existing polygon. When I run this code it creates a region ok but it creates the region as a new entity and duplicates the polygon. Is there a way to covert the selected polygon into a region with out duplicating?
<CommandMethod("CreateRegion")>
Public Sub CreateRegion()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = HostApplicationServices.WorkingDatabase
'Dim copied As ObjectIdCollection = New ObjectIdCollection()
'******Prompt user to select objects
Dim psr As PromptSelectionResult = doc.Editor.GetSelection()
'Dim acSSet As SelectionSet = psr.Value
If psr.Status = PromptStatus.OK Then
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim curves = New DBObjectCollection()
For Each obj As SelectedObject In psr.Value
curves.Add(tr.GetObject(obj.ObjectId, OpenMode.ForRead))
Dim regions = Region.CreateFromCurves(curves)
Dim curSpace As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
For Each region In regions
curSpace.AppendEntity(region)
tr.AddNewlyCreatedDBObject(region, True)
Next
Next
tr.Commit()
ed.WriteMessage("Region created")
End Using
End Sub
Shaban.
_gile
You have to explicitly erase the curves used to create the region.
Gilles Chanteau
GileCAD
GitHub
Do i do this before or after the tr.commit()??
_gile
Before. Transaction.Commit() saves the changes to Database done with the transaction.
Gilles Chanteau
GileCAD
GitHub
Hi, do you have some example code of explicitly erase the "curves" used to create the region.
Thanks In advance
_gile
        [CommandMethod("CreateRegion")]
        public static void CreateRegion()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var psr = ed.GetSelection();
            if (psr.Status != PromptStatus.OK)
                return;
            using (var tr = db.TransactionManager.StartTransaction())
                var curves = new DBObjectCollection();
                foreach (SelectedObject so in psr.Value)
                    var id = so.ObjectId;
                    if (id.ObjectClass.IsDerivedFrom(RXObject.GetClass(typeof(Curve))))
                        curves.Add(tr.GetObject(id, OpenMode.ForWrite));
                var regions = Region.CreateFromCurves(curves);
                var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                foreach (Region region in regions)
                    curSpace.AppendEntity(region);
                    tr.AddNewlyCreatedDBObject(region, true);
                foreach(Curve curve in curves)
                    curve.Erase();
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
