REFSET and REFCLOSE saving area
nam_h_tran
nam_h_tran
When i using refset to add or remove objects in working set. It will having the messing:
{ some objects) added to working set
{ some objects) remove from working set
And same with refclose when i save it will show the number of objects added and removed in working set.
My question is, how can i get these number? These objects which added into or removed from working set ( long transaction) should be saving somewhere right?
ActivistInvestor
In the comments of this devblog post, you will find a C# conversion of the article's C++ that shows how to access the information related to what you're after. I don't think there is any explicit property that tells you the number of objects added/removed from the working set, but you might be able to figure that out by handling some of the LongTransactionManager events (like CheckingOut)
nam_h_tran
Thank a lot. This is a great help
